Guest Posted June 6, 2015 [[Template forums/front/topics/post is throwing an error. This theme may be out of date. Run the support tool in the AdminCP to restore the default theme.]]
AndroidDeveloperLB Posted June 6, 2015 Report Share Posted June 6, 2015 Here's another problematic website: https://events.google.com/io2015/videos# For some reason, it doesn't show the videos. Tip Give Link to comment Share on other sites More sharing options...
Magdalene Posted June 6, 2015 Report Share Posted June 6, 2015 Both sites work fine in Retro mode. Tip Give Link to comment Share on other sites More sharing options...
~Ohke Posted June 6, 2015 Report Share Posted June 6, 2015 And Nitro can show all Icons + all the Videos (they are all in HTML5 format)... Nitro runs with this UA now... Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) MxNitro/1.1.0.2000 Chrome/39.0.2146.0 Safari/537.36 Page is shown in (UTF-8) = Maxthon also set to it.. Tried Nitro UA in Maxthon, but no go there ether... Retro is the only way it seams... (^^,) Best Regards Ohke Tip Give Link to comment Share on other sites More sharing options...
BugMiss006 Posted June 8, 2015 Report Share Posted June 8, 2015 Hi, Thanks for your question. It happens the same on my side. I will let our product department know about this. We will fix it as soon as possible. Have a nice day! Tip Give Link to comment Share on other sites More sharing options...
AndroidDeveloperLB Posted June 12, 2015 Report Share Posted June 12, 2015 Hi, Thanks for your question. It happens the same on my side. I will let our product department know about this. We will fix it as soon as possible. Have a nice day! Thank you. I think a lot of Google's websites have issues with maxthon. Here's another one : https://www.android.com/phones/whichphone/ (after pressing on "get started"). Tip Give Link to comment Share on other sites More sharing options...
Saitoukuni Posted June 12, 2015 Report Share Posted June 12, 2015 Hello, I wanted to test the new feature on the android website permitting to find the best suited android phone for the utilisation I'll make of it. However, it seems to be buggy in ultra mode: I get wrong icons and cannot select anything (see screenshots). No problem in Retro mode. I'm using Mx v4.4.5.3000. The feature can be accessed at: https://www.android.com/phones/whichphone/, you'll probably need to click on "get started" first. Tip Give Link to comment Share on other sites More sharing options...
-ody- Posted June 12, 2015 Report Share Posted June 12, 2015 Hello, I wanted to test the new feature on the android website permitting to find the best suited android phone for the utilisation I'll make of it. However, it seems to be buggy in ultra mode: I get wrong icons and cannot select anything (see screenshots). No problem in Retro mode. I'm using Mx v4.4.5.3000. The feature can be accessed at: https://www.android.com/phones/whichphone/, you'll probably need to click on "get started" first. ultra.png retro.png it works fine in ultra mode here did you try to disable ABP + ? Tip Give Link to comment Share on other sites More sharing options...
-ody- Posted June 12, 2015 Report Share Posted June 12, 2015 Thank you. I think a lot of Google's websites have issues with maxthon. Here's another one : https://www.android.com/phones/whichphone/ (after pressing on "get started"). this one works fine here. did you try to disable ABP ? Tip Give Link to comment Share on other sites More sharing options...
Saitoukuni Posted June 12, 2015 Report Share Posted June 12, 2015 it works fine in ultra mode here did you try to disable ABP + ? Yes I tried, problem is still present. I also tried to disable all extensions, without more succes. Tip Give Link to comment Share on other sites More sharing options...
7twenty Posted June 13, 2015 Report Share Posted June 13, 2015 Page won't even load after pressing "get started" in Ultra (ABP on & off). Works fine in Retro, or changing back to Ultra after the front page. Using default UA. For pages like this using Retro is a great fallback option. Seeing as there are no MX features that the site needs you don't really lose anything by not using Ultra (apart from having to change to Retro). I'm hoping the new blink core MX is coming soon. I'm thinking a lot of issues with websites will fixed once this happens. The current one is getting on a bit now. Tip Give Link to comment Share on other sites More sharing options...
-ody- Posted June 13, 2015 Report Share Posted June 13, 2015 Page won't even load after pressing "get started" in Ultra (ABP on & off). this is weird : why does it work here (ultra and ABP on), and not there.... Tip Give Link to comment Share on other sites More sharing options...
7twenty Posted June 13, 2015 Report Share Posted June 13, 2015 this is weird : why does it work here (ultra and ABP on), and not there.... Are you using the default UA? Tip Give Link to comment Share on other sites More sharing options...
-ody- Posted June 13, 2015 Report Share Posted June 13, 2015 Are you using the default UA? yes... Tip Give Link to comment Share on other sites More sharing options...
Guest Posted June 13, 2015 [[Template forums/front/topics/post is throwing an error. This theme may be out of date. Run the support tool in the AdminCP to restore the default theme.]]
-ody- Posted June 13, 2015 Report Share Posted June 13, 2015 You are really sure having the same result like below in Ultra mode? bug site andro.jpg weird : yesterday it worked, today it doesn't.. I even clicked several icons to check if the links worked nothing has changed on my system... I should have made a capture. Tip Give Link to comment Share on other sites More sharing options...
Guest Posted June 14, 2015 [[Template forums/front/topics/post is throwing an error. This theme may be out of date. Run the support tool in the AdminCP to restore the default theme.]]
AndroidDeveloperLB Posted June 15, 2015 Report Share Posted June 15, 2015 this one works fine here. did you try to disable ABP ? Still doesn't work well. Tip Give Link to comment Share on other sites More sharing options...
Saitoukuni Posted June 15, 2015 Report Share Posted June 15, 2015 Here another rendering issue I encounter right now: the EA live for E3 (http://livetoplay.ea.com/e3-press-conference) I hope the new core will shortly be deployed... Tip Give Link to comment Share on other sites More sharing options...
Guest Posted June 16, 2015 [[Template forums/front/topics/post is throwing an error. This theme may be out of date. Run the support tool in the AdminCP to restore the default theme.]]
