Chorong761 Posted May 18, 2015 Report Share Posted May 18, 2015 When I use Google maps with ultra mode, I am not able to use earth mode but in retro mode i could. Does ultra mode support earth mode? OS:Windows 8.1 on Maxthon 4.4.5.1800 Extensions :NoAds and Violent Monkey Skins: Chrome Skin Tip Give Link to comment Share on other sites More sharing options...
Guest Posted May 18, 2015 [[Template forums/front/topics/post is throwing an error. This theme may be out of date. Run the support tool in the AdminCP to restore the default theme.]]
-ody- Posted May 18, 2015 Report Share Posted May 18, 2015 When I use Google maps with ultra mode, I am not able to use earth mode but in retro mode i could. Does ultra mode support earth mode? actually it looks like I can't either : I tried to change the UA, but I only can see the simplified view.. Tip Give Link to comment Share on other sites More sharing options...
PHYR Posted May 18, 2015 Report Share Posted May 18, 2015 actually it looks like I can't either : I tried to change the UA, but I only can see the simplified view.. On win10 I can't see Gmaps in retro, only in ultra, so I have no idea whether I'm seeing simplified version or not. I've used both newly modified UA and no user agent. Tip Give Link to comment Share on other sites More sharing options...
Magdalene Posted May 18, 2015 Report Share Posted May 18, 2015 I get the Satellite Earth view in Ultra mode but not the red and white compass or the Tilt View button. I use the Minimalist UA. It's fine in Retro. The problem is caused because Google Maps doesn't function correctly with the old Chrome 30 Blink Core used by Maxthon. We will probably have to wait for the new core to arrive. Tip Give Link to comment Share on other sites More sharing options...
BugSir007 Posted May 19, 2015 Report Share Posted May 19, 2015 Hi guys, Am i doing something wrong? Google maps, earth view seems to work fine in both modes ... Tip Give Link to comment Share on other sites More sharing options...
BugMiss006 Posted May 19, 2015 Report Share Posted May 19, 2015 Hi, Thanks for your question.We tested on your problem.It is ok on our side. Tip Give Link to comment Share on other sites More sharing options...
7twenty Posted May 19, 2015 Report Share Posted May 19, 2015 Hi guys, Am i doing something wrong? Google maps, earth view seems to work fine in both modes ... Same here. Can't see any issues? Is there a difference in what is shown depending on what Chrome/webkit/blink version is used? There's definitely no error. Only thing I can think of is that Google is serving different data to different zones, some of which needs newer webkit/blink to run properly. Try running without signing in to your account or using Maxthon portable to test with and see if it makes a difference. If yes, then it's a settings thing. If no, then it's a google thing. Tip Give Link to comment Share on other sites More sharing options...
-ody- Posted May 19, 2015 Report Share Posted May 19, 2015 Same here. Can't see any issues? Is there a difference in what is shown depending on what Chrome/webkit/blink version is used? There's definitely no error. Only thing I can think of is that Google is serving different data to different zones, some of which needs newer webkit/blink to run properly. Try running without signing in to your account or using Maxthon portable to test with and see if it makes a difference. If yes, then it's a settings thing. If no, then it's a google thing. looks like we're not speaking about the same thing sorry it's in french. I can only access to simplied view, not earth 3d view Tip Give Link to comment Share on other sites More sharing options...
Magdalene Posted May 19, 2015 Report Share Posted May 19, 2015 This is what I get On MX 4.4.5.1800 (1st 2 images) and Nitro (last image) Tip Give Link to comment Share on other sites More sharing options...
Chorong761 Posted May 19, 2015 Author Report Share Posted May 19, 2015 This is what I get Yes, this is like what I get and this is the issue I wanted to address. Tip Give Link to comment Share on other sites More sharing options...
-ody- Posted May 19, 2015 Report Share Posted May 19, 2015 Yes, this is like what I get and this is the issue I wanted to address. exactly, get the same ! no matter ultra or retro, and whatever UA... but it may be related to graphic card too... Tip Give Link to comment Share on other sites More sharing options...
Guest Posted May 19, 2015 [[Template forums/front/topics/post is throwing an error. This theme may be out of date. Run the support tool in the AdminCP to restore the default theme.]]
Guest Posted May 20, 2015 [[Template forums/front/topics/post is throwing an error. This theme may be out of date. Run the support tool in the AdminCP to restore the default theme.]]
WislaHD Posted June 12, 2015 Report Share Posted June 12, 2015 Google Maps does not work when I switch to 3D mode. When I check why it does not work, it links me here: https://support.google.com/maps/answer/3096703?hl=en&authuser=0&p=requirements&rd=1 I am a big user of Google Maps so I would be very grateful if this can be looked at. Thank you! (using v4.4.5.3000 on Windows 8.1) Tip Give Link to comment Share on other sites More sharing options...
-ody- Posted June 12, 2015 Report Share Posted June 12, 2015 Google Maps does not work when I switch to 3D mode. When I check why it does not work, it links me here: https://support.google.com/maps/answer/3096703?hl=en&authuser=0&p=requirements&rd=1 I am a big user of Google Maps so I would be very grateful if this can be looked at. Thank you! (using v4.4.5.3000 on Windows 8.1) merged ! same issue here http://forum.maxthon.com/index.php/topic/15170-google-earth-in-ultra-mode/?hl=%2Bearth+%2Bmode Tip Give Link to comment Share on other sites More sharing options...
