websterx Posted August 24, 2018 Report Share Posted August 24, 2018 Hello. I'm experiencing a strange behavior on a dell optiplex 5050, a lot of web sites are unaccessible with error " Error code 7 (net::ERR_TIMED_OUT", if i switch the core to IE the site is working fine. Not all the sites are affected. The problem seems to start after last O.S. patch applied. Any suggestion? Refards. Ettore. Link to comment Share on other sites More sharing options...
No.1MaxthonFan Posted August 24, 2018 Report Share Posted August 24, 2018 2 hours ago, websterx said: Hello. I'm experiencing a strange behavior on a dell optiplex 5050, a lot of web sites are unaccessible with error " Error code 7 (net::ERR_TIMED_OUT", if i switch the core to IE the site is working fine. Not all the sites are affected. The problem seems to start after last O.S. patch applied. Any suggestion? Refards. Ettore. A link to any of those sites would be helpful to diagnose. Windows 10 64-bit build 10525/Windows 10 Mobile build 10512 Link to comment Share on other sites More sharing options...
websterx Posted August 27, 2018 Author Report Share Posted August 27, 2018 Sorry, you are right, some more information could help... I'm using Maxthon 5.4.2000 portable on Windows 10. Above system information. one example is site www.orlandopizzolato.com, if i try to connect using maxthon in ultra mode i receive the time out error, if i switch in retro mode work fine. same issue on other maxthon version 5 and 4. Version: 5.2.4.2000 OS: 10.0.17134. IE: 11.228.17134.0 Maxthon.exe = 5.2.4.2000 MxBrowser.dll = 2.0.5.380 mx_core.dll = 5.1.18.602 Maxzlib.dll = 2.2.3.10 MxService.dll = 1.0.98.18 MxAddonsMgr.dll = 5.3.0.14 MxCrashCatch.dll = 4.0.1.20 MxDb.dll = 5.37.19.10 MxDownloader.dll = 5.1.0.116 MxEncode.dll = 2.0.0.12 MxFilePackage.dll = 2.0.3.6 MxHttpRq.dll = 5.0.1.64 MxIPC.dll = 4.3.0.12 MxMsg.dll = 2.0.0.28 MxResMgr.dll = 5.2.8.302 MxRsc.dll = 5.0.0.28 MxTool.dll = 2.2.0.96 MxUI.dll = 3.3.3.158 MxXDR.dll = 2.1.0.10 MxCmpUrl.dll = 5.0.0.14 MxFav.dll = 4.0.0.22 MxFavDb.dll = 13.0.0.14 MxHistory.dll = 2.5.0.10 MxQRGen.dll = 2.1.0.8 MxSiteIcon.dll = 2.0.18.42 MxSmartUrl.dll = 3.0.0.46 MxStorage.dll = 2.0.6.24 MxMolebox.dll = 1.2.4.237 MxSync.dll = 3.0.2.28 MxUrlSec.dll = 3.0.0.42 MxAvatarExt.dll = 5.1.0.10 MxExtTools.dll = 4.0.1.26 MxAddonMisc.dll = 5.2.0.54 MxMsgPush.dll = 3.0.0.54 MxQrcLogin.dll = 1.0.0.10 MxSvInfo.dll = 3.2.0.30 Link to comment Share on other sites More sharing options...
caligula73 Posted August 27, 2018 Report Share Posted August 27, 2018 1 hour ago, websterx said: www.orlandopizzolato.com win7x64 + v5.4.2000 no problem Link to comment Share on other sites More sharing options...
BugSir006 Posted August 27, 2018 Report Share Posted August 27, 2018 How about the guest mode? Link to comment Share on other sites More sharing options...
websterx Posted August 27, 2018 Author Report Share Posted August 27, 2018 Hi. I'm using maxthon on other p.c. without problems, even on the same network. I run a virtual machine on this P.C. and maxthon work fine. No difference in guest mode or disabling all add-on. Last week all was working fine, seems that after O.S. patch start having this issue. It's a strange problem and i'm guessing if have some one any idea to troubleshoot this issue? Regards. Ettore. Link to comment Share on other sites More sharing options...
7twenty Posted August 27, 2018 Report Share Posted August 27, 2018 5 hours ago, websterx said: www.orlandopizzolato.com, if i try to connect using maxthon in ultra mode i receive the time out error, Every time? Or just occasionally? Try disabling pre-rendering, in settings > advanced > browsing Test with a portable version and see if it still happens. Link to comment Share on other sites More sharing options...
Magdalene Posted August 27, 2018 Report Share Posted August 27, 2018 Works fine here (UK) Win 10 and MX 5.2.4.2000. Link to comment Share on other sites More sharing options...
websterx Posted August 28, 2018 Author Report Share Posted August 28, 2018 Hello. The problem seems to be related to https, if i try to connect to a site using http and this site redirect me to an https version, i receive the timeout error. If i connect directly with https the site work fine. I've already tried to enable or disable all the option in advanced setiings and add-on. As i said it's a strange issue. Regards. Ettore. Link to comment Share on other sites More sharing options...
websterx Posted August 28, 2018 Author Report Share Posted August 28, 2018 I did a restore to the previous version of O.S. and now all is working fine. This version had problems Version: 5.2.4.2000OS: 10.0.17134.IE: 11.228.17134.0 This one work fine Version: 5.2.4.2000 OS: 10.0.10240. IE: 11.0.10240.17443 Link to comment Share on other sites More sharing options...
