Irbis9 Posted September 17, 2021 Report Share Posted September 17, 2021 All the time I'm trying MX6, the browser does what you can see in the video. With this issue the MX6 is not useable for me. Everytime I write something MX6 will interrupt it. And this happens all the time when the browser is opened. All over again. Please fix it! Otherwise I can't use this browser anymore. (I'm using Windows 8.1 Pro 64bit) Maxthon.mp4 Tip Give Link to comment Share on other sites More sharing options...
BugSir006 Posted September 18, 2021 Report Share Posted September 18, 2021 Hi 15675297, could you let me know the version number of your browser? How about the latest version 6.1.2.2901? Tip Give Link to comment Share on other sites More sharing options...
Irbis9 Posted September 18, 2021 Author Report Share Posted September 18, 2021 Thanks for your reply. It is still the same. (I use the portable version.) Tip Give Link to comment Share on other sites More sharing options...
BugSir009 Posted September 20, 2021 Report Share Posted September 20, 2021 On 9/19/2021 at 2:13 AM, 15675297 said: Thanks for your reply. It is still the same. (I use the portable version.) Hi 15675297, could you try the install version and see if you experience the same issue? Tip Give Link to comment Share on other sites More sharing options...
Irbis9 Posted September 21, 2021 Author Report Share Posted September 21, 2021 Nothing has changed with the install version. I don't know why is that. (And it is the same on my PC and laptop. Both with Windows 8.1.) I've tried to disable all extentions but nothing. Tip Give Link to comment Share on other sites More sharing options...
BugSir006 Posted September 23, 2021 Report Share Posted September 23, 2021 Hi 15675297, could you let me know your system theme? Did you use the latest version 6.1.2.2901? Please try this issue in the fresh portable version: https://dl.maxthon.com/mx6/maxthon_portable_6.1.2.2901_beta_x64.zip Tip Give Link to comment Share on other sites More sharing options...
BugSir006 Posted September 23, 2021 Report Share Posted September 23, 2021 Please try to disable the hardware acceleration then try this issue again. Tip Give Link to comment Share on other sites More sharing options...
Irbis9 Posted September 24, 2021 Author Report Share Posted September 24, 2021 Thank you for your reply, BugSir006. I deleted the old portable version and downloaded the latest one from the link you provided. I also tried to disable the hardware acceleration. But the issue is still the same. (What a system theme do you mean? Windows theme or Maxthon theme? In MX6 I use the classic theme.) Tip Give Link to comment Share on other sites More sharing options...
BugSir006 Posted September 26, 2021 Report Share Posted September 26, 2021 On 9/25/2021 at 1:12 AM, Irbis9 said: (What a system theme do you mean? Windows theme or Maxthon theme? Hi Irbis9, I mean the Windows system information of your device and the Windows system theme. 😊 Tip Give Link to comment Share on other sites More sharing options...
Irbis9 Posted September 26, 2021 Author Report Share Posted September 26, 2021 I have several themes which means that I use own wallpapers with automatic colour of windows. The Windows system information is following: Tip Give Link to comment Share on other sites More sharing options...
BugSir006 Posted September 26, 2021 Report Share Posted September 26, 2021 Hi Irbis9, could you try to test this issue in the attached version? mini_installer--debug.exe Tip Give Link to comment Share on other sites More sharing options...
Irbis9 Posted September 26, 2021 Author Report Share Posted September 26, 2021 There is no problem whith the attached version. I can write the whole time without any interruption. Tip Give Link to comment Share on other sites More sharing options...
BugSir006 Posted September 26, 2021 Report Share Posted September 26, 2021 Hi Irbis9, thank for your help! Could you try this issue in the attached test version again? Chromium89.zip Tip Give Link to comment Share on other sites More sharing options...
Irbis9 Posted September 26, 2021 Author Report Share Posted September 26, 2021 Thank you for your reply. In this version everything works fine. No problem. Tip Give Link to comment Share on other sites More sharing options...
BugSir006 Posted September 27, 2021 Report Share Posted September 27, 2021 Hi Irbis9, could we debug this issue remotely via AnyDesk? AnyDesk.exe Tip Give Link to comment Share on other sites More sharing options...
Irbis9 Posted September 27, 2021 Author Report Share Posted September 27, 2021 I'm not sure. Is it safe? If so we can try it. Tip Give Link to comment Share on other sites More sharing options...
BugSir006 Posted September 28, 2021 Report Share Posted September 28, 2021 13 hours ago, Irbis9 said: I'm not sure. Is it safe? If so we can try it. It is safe. Could you let me know your time zone? What time is convenient for you? Tip Give Link to comment Share on other sites More sharing options...
Irbis9 Posted September 28, 2021 Author Report Share Posted September 28, 2021 My time zone is Central European Summer Time. It is 9:45 clock now and I'm free all day today. So you can connect anytime. Tip Give Link to comment Share on other sites More sharing options...
BugSir006 Posted September 28, 2021 Report Share Posted September 28, 2021 1 hour ago, Irbis9 said: My time zone is Central European Summer Time. It is 9:45 clock now and I'm free all day today. So you can connect anytime. Hi Irbis9, could you let me know your AnyDesk ID? 😊 Tip Give Link to comment Share on other sites More sharing options...
Irbis9 Posted September 28, 2021 Author Report Share Posted September 28, 2021 You should receive a private message with my ID. Tip Give Link to comment Share on other sites More sharing options...
BugSir006 Posted September 28, 2021 Report Share Posted September 28, 2021 1 hour ago, Irbis9 said: You should receive a private message with my ID. Thank you for your help! The dev team will fix it as soon as possible. 😊 Tip Give Link to comment Share on other sites More sharing options...
Irbis9 Posted September 28, 2021 Author Report Share Posted September 28, 2021 Thank you very much for YOUR help. I'll be waiting. Tip Give Link to comment Share on other sites More sharing options...
Irbis9 Posted October 7, 2021 Author Report Share Posted October 7, 2021 Hi, BugSir006. I downloaded the latest version 6.1.2.3100 but the issue still continues. Should I wait for the next version which will fix it? Tip Give Link to comment Share on other sites More sharing options...
BugSir006 Posted October 8, 2021 Report Share Posted October 8, 2021 10 hours ago, Irbis9 said: Hi, BugSir006. I downloaded the latest version 6.1.2.3100 but the issue still continues. Should I wait for the next version which will fix it? Hi Irbis9, this issue is still being analyzed. Currently, I can not confirm the specific date. 😥 But I will urge them. ☺️ Tip Give Link to comment Share on other sites More sharing options...
Irbis9 Posted December 6, 2021 Author Report Share Posted December 6, 2021 Hi BugSir006. It is almost 2 months since your last message and the problem have not been fixed yet. I tried the 6.1.3.600 version and it is the same. Anything new? EDIT 18. 12.: I realized it happens only when I open normal window. The problem doesn't appear with the incognito window. Tip Give Link to comment Share on other sites More sharing options...
