DARKSTORM Posted October 5, 2014 Report Share Posted October 5, 2014 I'll just post this so maybe it can be fixed, This thing already happens often, the others tools are just gone and will need to close and reopen MX4 to fix it but after a while it happens again, I use resource sniffer mostly often but the icons disappear and only external tools remain 10114 Tip Give Link to comment Share on other sites More sharing options...
DARKSTORM Posted October 6, 2014 Author Report Share Posted October 6, 2014 Seems like whole day yesterday, If how many times happen out of how many times I open MX4, It can be 7 out of 10 Tip Give Link to comment Share on other sites More sharing options...
7twenty Posted October 6, 2014 Report Share Posted October 6, 2014 Any more info? Are you using a skin? Have you tried the default skin/theme? What happens when you show all/some of them on the toolbar? Do they still disappear? I disable the toolbar apart from one item which i've added and it has never disappeared. Tip Give Link to comment Share on other sites More sharing options...
DARKSTORM Posted October 6, 2014 Author Report Share Posted October 6, 2014 This is my usual tools present then after a while External Tools only remains and yes I'm using a skin, I'll try using default but may be somekind boring without using a skin, I've already tried default on the very first run but I didn't notice the tools disappearing Tip Give Link to comment Share on other sites More sharing options...
DARKSTORM Posted October 7, 2014 Author Report Share Posted October 7, 2014 Haven't notice those problems with default skin but resource sniffer icon is almost invisible(colorless) Mx4 needs some adjustments on skin Tip Give Link to comment Share on other sites More sharing options...
BugSir007 Posted October 8, 2014 Report Share Posted October 8, 2014 Hi DARKSTORM, Glad to talk with you. Really sorry fro the issue encountered. Here with the same version of Maxthon as yours, with even default skin, i seem to experience colorless toolbar icons problem. I'll let our development team know about this issue and try to do some adjustments. Thanks for supporting Maxthon. Tip Give Link to comment Share on other sites More sharing options...
Magdalene Posted October 8, 2014 Report Share Posted October 8, 2014 I've had the disappearing toolbar icon at startup problem since MX4 appeared. I just treated it as an annoyance and restarted Maxthon. I agree it needs to be fixed. For your colourless icons use a different background colour on yourskin. Tip Give Link to comment Share on other sites More sharing options...
