Galileusz
winpc issue violent monkey does not work
10 posts in this topic
On 23/8/2016 at 7:37 PM, Magdalene said:
Violentmonkey is working fine here. Make sure you have the latest version and switch it off and on when you install it.
For me, unfortunately, does not work. My version Mx5 is 5.0.1.1500, Violentmonkey 2.5.5. I tried a clean install and nothing. I have an icon in the sidebar, but scripts do not respond. I'll wait for the next version of the MX5 and maybe it will be repaired.
Really?  And where did you get that version.  :questionmark-smiley-01: old:titter:
2 people like this
A typo, it happens. 5.0.1.500 is correct :titter:
I know, I just wanted to tease you.  :p
1 person likes this
On 24/8/2016 at 11:33 PM, Galileusz said:
I've split this thread (each different issue has to be posted in a different thread in order to help devs tracking bugs)
violent monkey works fine here (at least the scripts I use).
Does it happen with all your scripts ? may you try this one please (which works fine here) https://greasyfork.org/en/scripts/735-anti-adblock-killer-reek
Not even one script doesn't work for me. anti-adblock-killer-reek I have also installed.   Recording_2016_08.rar
I wondered to remove all extensions and re-install them. But do not spoil my configuration MX4? Is MX5 is completely separated from the MX4?
at the moment you can't disable sync, and you can't use a guest account to test : if you remove your extensions in Mx5, I'm afraid they will be removed in Mx4 too (maybe you could try to disable the sync in Mx4 and/or backup your personal files just in case, the time you perform your tests ?)
all scripts I tried so far are working fine, the last one I just downloaded https://greasyfork.org/en/scripts/18463-youtube-mp3-direct-download-button works fine
In that case, I will not remove them. I'll wait for new version.
Thanks for your patience Galileusz:)
