scottchu.tw Posted September 9, 2021 Report Share Posted September 9, 2021 In older version, I can right click on the text box of usename or password and save them, not even needed to click ok button to trigger magic fill (which is an alternative way for me to create a new item in magic fill and can edit it later). Can I do it now in any way? Please see attached screenshots of magic fill in older version. 1st: Right click to bring up save form item. 2nd: Then I open magic fill window manually from setting. 3rd: Without the help of function in 1st screenshot, I can save an item into magic fill manually and use function in 3rd screenshot to edit it. This is always an alternative way for me to add new item in magic fill. Tip Give Link to comment Share on other sites More sharing options...
BugSir009 Posted September 9, 2021 Report Share Posted September 9, 2021 2 hours ago, scottchu.tw said: In older version, I can right click on the text box of usename or password and save them, not even needed to click ok button to trigger magic fill (which is an alternative way for me to create a new item in magic fill and can edit it later). Can I do it now in any way? Please see attached screenshots of magic fill in older version. 1st: Right click to bring up save form item. 2nd: Then I open magic fill window manually from setting. 3rd: Without the help of function in 1st screenshot, I can save an item into magic fill manually and use function in 3rd screenshot to edit it. This is always an alternative way for me to add new item in magic fill. Hi scottchu.tw, the save function will be added in near future. Currently, you could go to Passkeeper to edit if you want to. Tip Give Link to comment Share on other sites More sharing options...
