scottchu.tw Posted June 24, 2021 Report Share Posted June 24, 2021 When I click the ... on right of a message replied to a fb article, it will go back to top of page. It should just bring up a popup menu. This happens both in MX5 and MX6. Any solution? Link to comment Share on other sites More sharing options...
BugSir006 Posted June 24, 2021 Report Share Posted June 24, 2021 3 hours ago, scottchu.tw said: When I click the ... on right of a message replied to a fb article, it will go back to top of page. It should just bring up a popup menu. This happens both in MX5 and MX6. Any solution? Hi scottchu.tw, how about other browsers? Could you provide me a video of this issue? Link to comment Share on other sites More sharing options...
scottchu.tw Posted June 27, 2021 Author Report Share Posted June 27, 2021 On 6/24/2021 at 7:25 PM, BugSir006 said: Hi scottchu.tw, how about other browsers? Could you provide me a video of this issue? Other browsers are normal. Today I upgrade MX6 to 6.1.2.1600, the problem seems gone. However, MX5 still have this problem. But currently MX6 is not so easy to use. I upload a short video when using MX5 (v5.3.8.2000 portable) 20210627_191744.mp4 Link to comment Share on other sites More sharing options...
BugSir006 Posted June 28, 2021 Report Share Posted June 28, 2021 On 6/27/2021 at 6:57 PM, scottchu.tw said: Other browsers are normal. Today I upgrade MX6 to 6.1.2.1600, the problem seems gone. However, MX5 still have this problem. But currently MX6 is not so easy to use. I upload a short video when using MX5 (v5.3.8.2000 portable) 20210627_191744.mp4 Hi scottchu.tw, thank you for your reply. Maxthon doesn't have the plan to update the Maxthon 5 browser, so I recommend you to use the Maxthon 6. Link to comment Share on other sites More sharing options...
