Paul Corfield Posted September 30, 2016 Report Share Posted September 30, 2016 In MX5 v5.0.1.1700 when I click my avatar to go to the infobox, it rarely opens on the first click. Often it jumps to one of my other tabs that are open. Then I click my avatar again and then it opens infobox. Is that a known bug? Paul. Link to comment Share on other sites More sharing options...
ventage Posted September 30, 2016 Report Share Posted September 30, 2016 28 minutes ago, Paul Corfield said: In MX5 v5.0.1.1700 when I click my avatar to go to the infobox, it rarely opens on the first click. Often it jumps to one of my other tabs that are open. Then I click my avatar again and then it opens infobox. Is that a known bug? Paul. I have something similar. Nothing happens If you click once where arrows show on the screen shot. If you double click on that area it opens the infobox. If you click on the avatar it works as it should (on the first try). Link to comment Share on other sites More sharing options...
Paul Corfield Posted September 30, 2016 Author Report Share Posted September 30, 2016 Even when I click right in the middle of the avatar it usually takes two clicks, one click tends to jump to a tab that is open. Paul. Link to comment Share on other sites More sharing options...
PHYR Posted September 30, 2016 Report Share Posted September 30, 2016 3 hours ago, ventage said: I have something similar. Nothing happens If you click once where arrows show on the screen shot. If you double click on that area it opens the infobox. If you click on the avatar it works as it should (on the first try). This area is now used to move the window(new in .1700) Link to comment Share on other sites More sharing options...
baerjo Posted October 3, 2016 Report Share Posted October 3, 2016 I have the same issue. It seems to cycle through the tabs if you click once. If you double click it will usually get you to infobox. I didn't have this issue in the last Beta so guessing it's new. Maybe some attempted design implementation that didn't quite work? Link to comment Share on other sites More sharing options...
No.1MaxthonFan Posted October 3, 2016 Report Share Posted October 3, 2016 Works properly on an test build. Wait for the update. Windows 10 64-bit build 10525/Windows 10 Mobile build 10512 Link to comment Share on other sites More sharing options...
