Guest Posted March 21, 2016 [[Template forums/front/topics/post is throwing an error. This theme may be out of date. Run the support tool in the AdminCP to restore the default theme.]]
7twenty Posted March 22, 2016 Report Share Posted March 22, 2016 Make sure the windows settings are set correctly for a 4 speaker setup. Disable "always use Ultra Mode" to make sure any sites that need Retro actually work. Enable "standard rendering in retro mode" to make sure any sites that use Retro do so with the most recent version. Update flash by following the instructions here. Tip Give Link to comment Share on other sites More sharing options...
7twenty Posted March 23, 2016 Report Share Posted March 23, 2016 Don't create multiple posts about the same issues. Continue this discussion in your previous thread. Locked. Tip Give Link to comment Share on other sites More sharing options...
BugMiss006 Posted March 23, 2016 Report Share Posted March 23, 2016 Hi~ could you tell me the extensions name? and I can let our test team to verify this issue is a bug or not. Tip Give Link to comment Share on other sites More sharing options...
BugMiss006 Posted March 23, 2016 Report Share Posted March 23, 2016 8 minutes ago, Clue4me58 said: it's disable html 5 it allows me to use flash player when watching you tube videos out of all 4 of my speakers. but it's not working now for some reason I tried it it's version 15.o,o,189. so I guess I didn't install the new version of flash the right way we will update flash plug-in in the next version. please have a try. it may release tomorrow. Thanks for you help us to improve our browser. Have a nice day~ Tip Give Link to comment Share on other sites More sharing options...
BugMiss006 Posted March 23, 2016 Report Share Posted March 23, 2016 39 minutes ago, Zurobara said: You should do intensive testing for flash player in win 8.1 pro (especially on facebook)..This is an old issue on both versions (4.8.xxx and 4.9.xxx) Thanks your proposal~ i already suggested our test team to do that~ Hope you continue make proposals for help us improving our browser~ we are always trying to do the best browser~ Tip Give Link to comment Share on other sites More sharing options...
Magdalene Posted March 23, 2016 Report Share Posted March 23, 2016 Quote adobe flash npapi is installed in my add and remove programs. So it looks Like I have correct version of flash installed properly with maxthon For 4.9 You need the Pepperflash PPapi Flash installed as pepflashplayer.dll in Core\plugins\Blink folder. There should be no Webkit folder. For 4.4 just delete the Flash file in Core\Plugins\Webkit. There should be no Blink folder. Tip Give Link to comment Share on other sites More sharing options...
magg Posted March 24, 2016 Report Share Posted March 24, 2016 22 minutes ago, Clue4me58 said: For 4.9 You need the Pepperflash PPapi Flash installed as pepflashplayer.dll in Core\plugins\Blink folder. There should be no Webkit folder. so how do I get this version of flash installed that you are talking about and delete the version I have I follwed instructions specific to what it said I needed to download for flash to use with Maxthon? Also when I switch to maxthons retro mode in you tube it uses an older version of flash version 15 how do I get retromode to use the latest version of flash like ultra mode does. can you sendme a link with instructions for both of my issues? Thank you! You already got these instructions... Anyway once again - http://forum.maxthon.com/index.php?/topic/13262-adobe-flash-and-maxthon/ Tip Give Link to comment Share on other sites More sharing options...
SnowLeopard Posted March 24, 2016 Report Share Posted March 24, 2016 3 hours ago, Zurobara said: In Maxthon 4.9.2.400 - portable is no "pepflasplayer.dll.org" file like in image from your link Of courese tthe wouldn't be any pepperflasshplayer.dll.org if you didn't ffollow the suggesstion in the instructions to rename the original copy to disable it raqther thaan deleting it. Then you copy the pepperflashplayer32_xx_x_x_xxx.dll fromC:\Windows\SysWOW54\Macromed\Flash\ and past it into the *\Core\Blink\Plugins\ folder in your Maxthon oor MaxthonPortable director. The image showss what it will look like AFTER you follow the directions provided you choose to keep the original versio availabble. You may also delete it if that suits you better. <<SL>> Tip Give Link to comment Share on other sites More sharing options...
7twenty Posted March 24, 2016 Report Share Posted March 24, 2016 I didn't think the instructions were that hard to understand?! Have revised them slightly to make it more clearer that .org is a renamed file. Tip Give Link to comment Share on other sites More sharing options...
7twenty Posted March 24, 2016 Report Share Posted March 24, 2016 3 minutes ago, Zurobara said: maybe i'm crazy. Not crazy, just not reading it from top to bottom as it should be. Jumping to whatever bits seem most pertinent to you, or just looking at the pictures isn't the way to do it. Copy/paste from thread: Quote Open an Explorer window (Win+E) and go to the folder you installed Maxthon to, then navigate to the \Core\Blink\plugins folder. NOTE: Default install folders are:32bit - C:\Program Files\Maxthon 64bit - C:\Program Files (x86)\Maxthon In this folder there should be a file called pepflashplayer.dll. Rename (eg. append .org to the filename) or delete this file only. Renaming is the recommended option. Copy pepflashplayer32_XX_X_X_XXX.dll from the windows folder to the Maxthon \Core\Blink\plugins folder, and rename it to pepflashplayer.dll. The original instruction stated: Rename (preferred) or delete this file only. I didn't think it was that obscure when read along with the image. Regardless, the instructions are correct and not hard to follow and lead to the desired outcome if followed correctly. Tip Give Link to comment Share on other sites More sharing options...
