FeNiX XG0D Posted July 26, 2014 Report Share Posted July 26, 2014 1080p videos on fullscreen are not an usual problem, but with maxthon I find myself unable to enjoy youtube in fullscreen, the video is slow and have missing frames. If I open any other browser the fullscreen works fine. Link to comment Share on other sites More sharing options...
Magdalene Posted July 26, 2014 Report Share Posted July 26, 2014 Update maxthon to the latest stable version - 4.4.1.3000. Link to comment Share on other sites More sharing options...
FeNiX XG0D Posted July 26, 2014 Author Report Share Posted July 26, 2014 Uhh wut? Link to comment Share on other sites More sharing options...
BugSir007 Posted July 27, 2014 Report Share Posted July 27, 2014 Hello FeNiX XG0D, Glad to talk to you. We deeply apologize for the inconvenience. Does the problem occur only with youtube videos? Maybe you can disable"GPU Acceleration"(Maxthons advanced settings) and try again. Also,if you are running any particular extensions,you may disable them for a while to see if everything works fine. If these sugestions do not solve your problem,please feel free to let us know. Thanks for your support. Link to comment Share on other sites More sharing options...
FeNiX XG0D Posted July 27, 2014 Author Report Share Posted July 27, 2014 Hello BugSir007, thanks for the answer, I jumped straight to disable the GPU Acceleration, and it made my whole experience worst... There was no extension running, so I tried downloading the latest portable version, and it quite work out. I think the problem may be around my instalation, but im not sure enough. EDIT: Found the youtube workaround, now is working fine Link to comment Share on other sites More sharing options...
FeNiX XG0D Posted July 27, 2014 Author Report Share Posted July 27, 2014 Followed this one @joemax http://forum.maxthon.com/thread-11008-1-1.html Link to comment Share on other sites More sharing options...
BugSir007 Posted July 28, 2014 Report Share Posted July 28, 2014 Hi FeNiX XG0D, Sorry for the worse experience caused by disabling GPU :L As you said, maybe you could check your installation. A clean install would be more helpful. Thanks. Link to comment Share on other sites More sharing options...
