vedicaudio Posted May 8 Report Share Posted May 8 Hello, I have the latest version of MX7 installed on two machines, both logged in and syncing. I have turned off "show searchbox" and "show weather" at least 5 times between the two machines, and I click "sync" quickaccess after doing so. MX7 just keeps turning them back on, on both machines. It seems that MX7 just ignores user preference and forces searchbox and weather to display each time it is restarted. Tip Give Link to comment Share on other sites More sharing options...
BugSir009 Posted May 9 Report Share Posted May 9 8 hours ago, vedicaudio said: Hello, I have the latest version of MX7 installed on two machines, both logged in and syncing. I have turned off "show searchbox" and "show weather" at least 5 times between the two machines, and I click "sync" quickaccess after doing so. MX7 just keeps turning them back on, on both machines. It seems that MX7 just ignores user preference and forces searchbox and weather to display each time it is restarted. Hi vedicaudio, do you have any extensions in place? And may I know if you are using the installed or portable version? Tip Give Link to comment Share on other sites More sharing options...
