I8U69 Posted July 10, 2016 Report Share Posted July 10, 2016 I dont use the IE11 that came ''factory'' with the Windows 8.1 laptop I have, but Maxthon uses IE's proxy server ..... but these pop-ups that say ''high CPU usage / Maxthon cloud browser'' from my webpage are happening way too much! all my devices are updated and it's not the flash player what could it be? (I'll try anything to reduce high CPU even if it means removing internet explorer) ... what should I do? (OS): windows 8.1 (64 bit) w/o the new Windows 10 (didn't like it) thx in advance ... Link to comment Share on other sites More sharing options...
No.1MaxthonFan Posted July 10, 2016 Report Share Posted July 10, 2016 Try unchecking the "Use IE Proxy" and see if that helps. Windows 10 64-bit build 10525/Windows 10 Mobile build 10512 Link to comment Share on other sites More sharing options...
I8U69 Posted July 10, 2016 Author Report Share Posted July 10, 2016 1 hour ago, No.1MaxthonFan said: Try unchecking the "Use IE Proxy" and see if that helps. ii've tried everything, including that .... and still getting CPU popup mssgs (it's probably a simple fix, but what the h*ll could it be, #1MF?) Link to comment Share on other sites More sharing options...
No.1MaxthonFan Posted July 10, 2016 Report Share Posted July 10, 2016 5 minutes ago, I8U69 said: ii've tried everything, including that .... and still getting CPU popup mssgs (it's probably a simple fix, but what the h*ll could it be, #1MF?) Have you tried this? Windows 10 64-bit build 10525/Windows 10 Mobile build 10512 Link to comment Share on other sites More sharing options...
-ody- Posted July 10, 2016 Report Share Posted July 10, 2016 forgive me if it is an odd question, but how unisntalling ie is supposed to reduce maxthon CPU usage in ultramode ? Link to comment Share on other sites More sharing options...
No.1MaxthonFan Posted July 10, 2016 Report Share Posted July 10, 2016 1 hour ago, -ody- said: forgive me if it is an odd question, but how unisntalling ie is supposed to reduce maxthon CPU usage in ultramode ? Have no idea, but he is asking how to disable, so am giving him some options. Windows 10 64-bit build 10525/Windows 10 Mobile build 10512 Link to comment Share on other sites More sharing options...
-ody- Posted July 10, 2016 Report Share Posted July 10, 2016 I have some questions : Which maxthon version ? and how old/powerful is your laptop ? how many pages are open when this happens (ie lots of running videos at the same time ? games ?) did you try another browser and do you encounter the same issue ? Link to comment Share on other sites More sharing options...
7twenty Posted July 11, 2016 Report Share Posted July 11, 2016 21 hours ago, I8U69 said: but these pop-ups that say ''high CPU usage / Maxthon cloud browser'' from my webpage are happening way too much! What is saying this? And answers as asked by ody above would be helpful. Link to comment Share on other sites More sharing options...
