SUBLIMIS Posted April 12, 2016 Report Posted April 12, 2016 adblock is do not work now. is anyone know the problem?
7twenty Posted April 13, 2016 Report Posted April 13, 2016 Is it enabled? Is a blocklist enabled? Is it on all sites or just one?C Can you provide a site that it doesn't work on so we can check if it needs a new/modified rule? What have you done to try and resolve the problem? Help us to help you, by providing at least something to work with.
jugurtha Posted April 26, 2016 Report Posted April 26, 2016 THIS problem in maxthon 4.9.2.1000 and new version
-ody- Posted April 27, 2016 Report Posted April 27, 2016 6 hours ago, 13585117 said: THIS problem in maxthon 4.9.2.1000 and new version please read post above and give us some more informations. Thank you
-ody- Posted April 27, 2016 Report Posted April 27, 2016 58 minutes ago, HPB1 said: You can also try this : NoAds extension it removes ads in youtube,FB,and other Websites, etc ...(see Image)! link: http://extension.maxthon.com/detail/index.php?view_id=2639 a better idea would be to understand what exactly is their issue
jugurtha Posted April 27, 2016 Report Posted April 27, 2016 - Is it enabled? yes is it enable. - Is a blocklist enabled? yes blocklist enabled - Is it on all sites or just one?C is it on all sites. - What have you done to try and resolve the problem? I uninstall maxthon and reinstall one more time. That does not work.
-ody- Posted April 27, 2016 Report Posted April 27, 2016 1 hour ago, jugurtha said: - Is it enabled? yes is it enable. - Is a blocklist enabled? yes blocklist enabled - Is it on all sites or just one?C is it on all sites. - What have you done to try and resolve the problem? I uninstall maxthon and reinstall one more time. That does not work. which maxthon version do you use ? and just to be sure you did not miss something : there are sevral places where you can enable AB+ (from menu, and from icon in status bar)
jugurtha Posted April 27, 2016 Report Posted April 27, 2016 maxthon version 4.9.2.1000 and this video : https://www.youtube.com/watch?v=3AyLbB4okHA&feature=youtu.be
7twenty Posted April 28, 2016 Report Posted April 28, 2016 Post removed seeing as I was watching the wrong video!!
PHYR Posted April 28, 2016 Report Posted April 28, 2016 18 minutes ago, 7twenty said: Not sure how that video has anything to do with Maxthon? Maxthon already has ABP builtin, you don't need to install anything or even turn it on. It should already be enabled and working. Make sure your settings are as below, and check on http://www.telegraph.co.uk/#source=refresh to see the difference between AdBlockPlus being on/off. AdBlock Plus Menu AdBlock Plus Settingshttp://www.telegraph.co.uk/ > ABP ONhttp://www.telegraph.co.uk/ > ABP OFF He was demonstrating how AB+ works when he isn't logged in and not working when he's logged in.
7twenty Posted April 28, 2016 Report Posted April 28, 2016 Removed the post. Seems it was running in the background and switched over to the next video without me noticing. All I can suggest is turning off/on any ABP related option. On the menu/options dialog/extensions page. See if that fixes the issue. Also deleting the blocklist/s currently selected and add them again.
klu Posted April 28, 2016 Report Posted April 28, 2016 4.9.3.100 Log in automatically - ABP works Enter the password to login - ABP is not working
-ody- Posted April 28, 2016 Report Posted April 28, 2016 4 hours ago, klu said: 4.9.3.100 Log in automatically - ABP works Enter the password to login - ABP is not working from there, you should be able to find the culprit : could be an extension, or a setting edit : I didn't correctly read your post
PHYR Posted April 28, 2016 Report Posted April 28, 2016 37 minutes ago, -ody- said: from there, you should be able to find the culprit : could be an extension, or a setting I have the same extensions and settings whether I login automatically or maunually. ???????????????
jugurtha Posted April 28, 2016 Report Posted April 28, 2016 Quote Removed the post. Seems it was running in the background and switched over to the next video without me noticing. All I can suggest is turning off/on any ABP related option. On the menu/options dialog/extensions page. See if that fixes the issue. Also deleting the blocklist/s currently selected and add them again. thank you for this solution and new problem after first problem : Adblock is enabled manually for run in next video: https://www.youtube.com/watch?v=aSBcZnOiSj0
