Chorong761 Posted May 19, 2015 Report Share Posted May 19, 2015 When i open pages like google, wikipedia, etc, it would open using retro mode even after i switched it back to ultra mode. Tip Give Link to comment Share on other sites More sharing options...
PHYR Posted May 19, 2015 Report Share Posted May 19, 2015 When i open pages like google, wikipedia, etc, it would open using retro mode even after i switched it back to ultra mode. Which tab did you last close while on that site? Maxthon remembers the mode of the last tab closed of a particular site. Tip Give Link to comment Share on other sites More sharing options...
BugMiss006 Posted May 19, 2015 Report Share Posted May 19, 2015 Hi, Thanks for your response. If your page is in Retro mode before you close it, our browser will remember it, and next time the same page will be opened in the same Retro mode.This remembering fuction works the same in Ultra mode, you can choose the right mode you like before you close the tab or the browser.And next time you open the same page, you will find the right mode you want.I hope this could help you. Do not hesitate to contact us if you are still confused. Tip Give Link to comment Share on other sites More sharing options...
7twenty Posted May 19, 2015 Report Share Posted May 19, 2015 I'd be trying a clean install. You seem to have a few issues going on based on the last few threads started. And from what's been noted most are not issues that many or any users are having. As stated above, Maxthon should remember the last mode a site was using. If it's not, something is not being saved correctly. Tip Give Link to comment Share on other sites More sharing options...
Chorong761 Posted May 19, 2015 Author Report Share Posted May 19, 2015 after i opened the tab and i see it in retro mode, i switched it back to ultra mode before i closed it since i know maxthon would remember what mode i used before but the next time it would open in retro mode again. I seem to have a lot of problems with the latest 1800 beta like crashes, retro mode issues, etc... Tip Give Link to comment Share on other sites More sharing options...
-ody- Posted May 19, 2015 Report Share Posted May 19, 2015 as 7twenty stated above, you should perform a clean install (unless you already did it)Please follow the steps in the Troubleshooting thread. Tip Give Link to comment Share on other sites More sharing options...
