mdc3161 Posted May 18, 2015 Report Share Posted May 18, 2015 I have quit using Maxthon due to the fact that MSN does not display correctly. It tries to display it correctly when I take it out of Ultra mode, but as soon as the slider finishes loading it just turns white. I can load it in any other browser and it works fine. Tip Give Link to comment Share on other sites More sharing options...
Guest Posted May 18, 2015 [[Template forums/front/topics/post is throwing an error. This theme may be out of date. Run the support tool in the AdminCP to restore the default theme.]]
7twenty Posted May 18, 2015 Report Share Posted May 18, 2015 Just tested with Maxthon and Firefox and I can't see any issues? Seems the same apart from some difference in the text and the 2nd tab bar you have to scroll slightly to see the last tab. Some more details on the issue would be nice. Tip Give Link to comment Share on other sites More sharing options...
No.1MaxthonFan Posted May 19, 2015 Report Share Posted May 19, 2015 Just tested with Maxthon and Firefox and I can't see any issues? Seems the same apart from some difference in the text and the 2nd tab bar you have to scroll slightly to see the last tab. Some more details on the issue would be nice. Like you, I have no problem with MSN. Displays just fine for me. Windows 10 64-bit build 10525/Windows 10 Mobile build 10512 Tip Give Link to comment Share on other sites More sharing options...
BugMiss006 Posted May 19, 2015 Report Share Posted May 19, 2015 Hi, Thanks for your response. We have tested on MSN you mentioned .The page dispalyed well on our side. Have a nice day! Tip Give Link to comment Share on other sites More sharing options...
