A.S. Posted August 18, 2014 Report Share Posted August 18, 2014 I have just learned about release of Maxthon 4.4.1.4000 with the new quick access. I checked the update to Menu -> About. Nothing. But it is normal for Maxthon. It never worked! I uninstalled Maxthon, downloaded new version from the website and installed it. But I do not see a new Quick Access here! And I see the icon NoAds icon in sidebar! But it must be in toolbar! Are you sure that this is a new version? And if I use MX as a guest, I see "Preferred Bookmarks" and "Unfiled Bookmarks" (I use the Russian version). But there not when I login. How to skip my settings to defaults? Link to comment Share on other sites More sharing options...
Guest Posted August 18, 2014 Report Share Posted August 18, 2014 This is a monumental error! 4.4.1.4000 = old QA 4.4.2.1400-beta = new QA Link to comment Share on other sites More sharing options...
A.S. Posted August 18, 2014 Author Report Share Posted August 18, 2014 Oliver One replied at 2014-8-18 18:42 This is a monumental error! 4.4.1.4000 = old QA 4.4.2.1400-beta = new QA Open lik. It's about 4.4.1.4000 and new QA. And what about default settings? Link to comment Share on other sites More sharing options...
A.S. Posted August 18, 2014 Author Report Share Posted August 18, 2014 A.S. replied at 2014-8-18 22:32 Open lik. It's about 4.4.1.4000 and new QA. And what about default settings? Is it about link? It's official Maxthon's blog. If it's about settings, for example? I can disable synchronization. But when I turn on sync again my settings will back. And I can remove folder from PC, but sync will return everything. I don't know how to skip settings. Link to comment Share on other sites More sharing options...
BugSir007 Posted August 19, 2014 Report Share Posted August 19, 2014 Hi guys, Thank you for your feedbacks. Really sorry, that was a mistake in changelog.:L There is no New Quick Access layout in Maxthon 4.4.1.xxx The New quick access was introduced in Maxthon 4.4.2.xxx We are going to fix this mistake. Thanks for your attention and support of Maxthon.:handshake Link to comment Share on other sites More sharing options...
A.S. Posted August 22, 2014 Author Report Share Posted August 22, 2014 BugSir007 replied at 2014-8-19 10:26 Hi guys, Thank you for your feedbacks. Really sorry, that was a mistake in changelog. There is no ... How to reset my settings? I can do it in Chrome. I can do it in Firefox. Why not in Maxthon? Link to comment Share on other sites More sharing options...
SWFlash0 Posted August 22, 2014 Report Share Posted August 22, 2014 A.S. replied at 2014-8-22 23:25 How to reset my settings? I can do it in Chrome. I can do it in Firefox. Why not in Maxthon? There we go again, open your eyes and you'll see everything Link to comment Share on other sites More sharing options...
A.S. Posted August 22, 2014 Author Report Share Posted August 22, 2014 SWFlash0 replied at 2014-8-23 02:29 There we go again, open your eyes and you'll see everything But it doesn't work for quick access, bookmarks, extensions, etc. It does not wokr for everything which sync with my MX account. Only for settings. It's not what I want. I want reset all settings as in Firefox or in Chrome. Link to comment Share on other sites More sharing options...
A.S. Posted August 22, 2014 Author Report Share Posted August 22, 2014 I can press "Restore defaults", close browser, delete account folder... But when I'll login again all my settings will be return... What do you do when you have problem with other browser? You reset settengs to default. It's useless in MX becose of sync. You cannot reinstall browser. Synchronization should work otherwise! I want to get full default settings in my account. How do it? Link to comment Share on other sites More sharing options...
