15571392 Posted June 30, 2014 Report Share Posted June 30, 2014 Hi! I have a problem with Facebook using Ultramode. List of my friends latest activity (list in the upper right corner of the Fb window)doesn't work properly. It works only for a few moments after entering the site, then when i click on someones activity nothing happens (doesn't expand the new window - what the acivity was). Sometimes if i will scrool down this list and click smthn., it shows me this window for a split of a second and disapears. Anyone with similar problems? Tip Give Link to comment Share on other sites More sharing options...
BugSir007 Posted July 1, 2014 Report Share Posted July 1, 2014 Hi, Glad to talk to you. I'm really sorry for any inconveniences brought to your browsing experience. Not quite sure if you are talking about the notification window but here i tried to run a test and everything works fine. Would be better if you elaborate or use a screenshot to let us see where you are referring. At the same time, i suggest you to upgrade to the latest beta version of Maxthon http://forum.maxthon.com/thread-11692-1-1.html Looking forward to hearing from you. Thanks for your support! Tip Give Link to comment Share on other sites More sharing options...
15571392 Posted July 1, 2014 Author Report Share Posted July 1, 2014 Thank You for Your response. Made a clean instal of new beta - still the same. I'm talking about the list (2) and notifications(1) in red squares. Those notifications which are visable (top of red box nr 2) works fine for a moment, then they stop appearing. When i will scrool down this list (red box 2), to see older activity, those windows (box 1) either do not apear at all or jut appear for a split of a second. I hope You can understand what i'm trying to say. Tip Give Link to comment Share on other sites More sharing options...
15571392 Posted July 9, 2014 Author Report Share Posted July 9, 2014 I kinda figured it out. It works only if the page is zoomed 100% otherwise it doesn't... Tip Give Link to comment Share on other sites More sharing options...
15571392 Posted July 12, 2014 Author Report Share Posted July 12, 2014 So, any1 can confirm that? Tip Give Link to comment Share on other sites More sharing options...
