MX 4.4.1.100 opening in second monitor
Posted
MX 4.4.1.1000 is my default browser.
All of a sudden it started opening in my second (dual) monitor; even when the monitor isn't turned on it still opens in that monitor. All other browsers and apps open in the default primary monitor.
Not sure what I did to cause it.
Got tip?
Thanks, Kerry
  • 1 month later...
Posted
I see this happen also but thought it was related to my secondary monitor, a somewhat out dated TV using generic drivers. It has other issues too, such as remaining "On" when shutting the PC down.
  • 1 month later...
Posted
Update: It's happening again. I don't know what I did differently. IE, FF, Opera, and SlimBrowser are all opening correctly in my primary (main monitor)
Kerry
Windows 8.1
Maxthpm 4.4.1.3000
Posted
Hi,
Really sorry for the inconvenience.
Here we tried again and again but we never reproduced your problem.
Do you close the browser when it is maximized? Un-maximize it before moving it to the primary screen and try gain.
You may refer to this document http://answers.microsoft.com/en-us/windows/forum/windows_7-desktop/application-adobe-reader-opens-in-external-monitor/b1dbc179-672c-4c98-8f71-a892a4a69a28
Also, you can help us by taking a video record of the two monitors to see how your problem is reproduced.
Looking forward to hearing from you.
Thanks for your support.
Posted
Update: Problem solved. What works is to maximize the Maxthon browser window and then click close, it then opens correctly in the primary monitor.
Much thanks to all,
Kerry
