mrxrsd Posted July 6, 2015 Report Share Posted July 6, 2015 Hi, I don´t know if it was coincidence or not, but in the latest releases of maxthon there are several sites that are showing issues like slow and flicker rendering. http://www.bonappetit.com/entertaining-style/trends-news/article/spiralizer http://globoesporte.globo.com/sp/futebol/libertadores/jogo/15-04-2015/danubio-sao-paulo/ Regards, Thiago Link to comment Share on other sites More sharing options...
-ody- Posted July 6, 2015 Report Share Posted July 6, 2015 both sites : I confirm, they load faster in IE both work fine when ABP + is disabled Link to comment Share on other sites More sharing options...
BugMiss006 Posted July 8, 2015 Report Share Posted July 8, 2015 Hi mrsrxd, Thanks for your question.I see no difference with or without ABP open in this page. Imgines are loaded quickly on my side.It is as same as that in Chrome.Does this problem happen the same in chrome on your side? Link to comment Share on other sites More sharing options...
mrxrsd Posted July 9, 2015 Author Report Share Posted July 9, 2015 Hi mrsrxd, Thanks for your question.I see no difference with or without ABP open in this page. Imgines are loaded quickly on my side.It is as same as that in Chrome.Does this problem happen the same in chrome on your side? No, I tried in several browsers (firefox, chrome, vivaldi...), I experienced slowness only in Maxthon. Indeed, after disabling ABP it was actually more fluid but not as Chrome. I will try a clean install, I think I have never done this since mx 4 first release. I think I wasn't clear in my first post but the issue isn't loading but scrolling. Link to comment Share on other sites More sharing options...
BugMiss006 Posted July 10, 2015 Report Share Posted July 10, 2015 Hi mrxrsd, Really sorry for your inconvenience. I tried again.It is indeed very slow than that in Chrome. It seemed not a problem caused by ABP. I would say it maybe a core triggered problem. We have confirm this. And I hope this would be fixed this ASAP. Thanks for your patience. Link to comment Share on other sites More sharing options...
Dinataspace Posted July 11, 2015 Report Share Posted July 11, 2015 Both are pretty much contains graphic content, I think disabling GPU hardware acceleration will help you to reduce the flicker/lag issue. Link to comment Share on other sites More sharing options...
