skidude2 Posted May 21 Report Share Posted May 21 I had to do a factory reset on my phone a few days ago. Whilst my Favorites have all synced Passkeeper has not and shows no inclination to do so. I have logged in at uu.me but it will not sync from there. Auto Sync is on as is only WiFi Sync. What is the official syncing method? Link to comment Share on other sites More sharing options...
BugSir009 Posted May 23 Report Share Posted May 23 On 5/22/2024 at 1:43 AM, skidude2 said: I had to do a factory reset on my phone a few days ago. Whilst my Favorites have all synced Passkeeper has not and shows no inclination to do so. I have logged in at uu.me but it will not sync from there. Auto Sync is on as is only WiFi Sync. What is the official syncing method? Hi skidude2, may I know which version are you using? Link to comment Share on other sites More sharing options...
skidude2 Posted May 23 Author Report Share Posted May 23 BugSir009 It says 7.0.5.1000 which I assume was installed from PlayStore following my reset. Link to comment Share on other sites More sharing options...
BugSir009 Posted May 24 Report Share Posted May 24 12 hours ago, skidude2 said: BugSir009 It says 7.0.5.1000 which I assume was installed from PlayStore following my reset. Hi skidude2, could you try out the attached test version? mx_five_pre_m6_mx6_ceed328_22570_7.4.3.700_proguard_202405071606.apk Link to comment Share on other sites More sharing options...
skidude2 Posted May 24 Author Report Share Posted May 24 OK I will deal with it. Link to comment Share on other sites More sharing options...
skidude2 Posted May 25 Author Report Share Posted May 25 That fixed it immediately. Many thanks. 1 Link to comment Share on other sites More sharing options...
skidude2 Posted May 27 Author Report Share Posted May 27 Not now fixed really as you have given with one hand and taken away with the other. Yes I have passkeeper operational but the installed version does not have Adblocker and I have all the ads flashing at me. I find the ads worse than the absence of passkeeper so I have reverted to 7.0.5.1000 again. Is there a version that has both adblocker and passkeeper sync that I can use. My PC portable Maxthon has now suddenly lost all my favorites ans will not resync them all Grrrrr. Link to comment Share on other sites More sharing options...
BugSir009 Posted May 28 Report Share Posted May 28 8 hours ago, skidude2 said: Not now fixed really as you have given with one hand and taken away with the other. Yes I have passkeeper operational but the installed version does not have Adblocker and I have all the ads flashing at me. I find the ads worse than the absence of passkeeper so I have reverted to 7.0.5.1000 again. Is there a version that has both adblocker and passkeeper sync that I can use. My PC portable Maxthon has now suddenly lost all my favorites ans will not resync them all Grrrrr. Hi skidude2, have you enabled the adblock extension or it is enable but not working? And can I know which portable version are you using? Link to comment Share on other sites More sharing options...
skidude2 Posted May 28 Author Report Share Posted May 28 6 hours ago, BugSir009 said: Hi skidude2, have you enabled the adblock extension or it is enable but not working? And can I know which portable version are you using? I am talking about the Android version. As far as I can see there is no add on for AdBlock Plus, it seems to be built in to the instal from Playstore. It is there in V7.0.5.1000 but not in the version you sent to me which fixed the passkeeper issue. Link to comment Share on other sites More sharing options...
skidude2 Posted May 31 Author Report Share Posted May 31 (edited) Any update on this please as the ads are soooo annoying. How can I install AdBlock on android on the test version you provided ? Edited May 31 by skidude2 Link to comment Share on other sites More sharing options...
BugSir009 Posted May 31 Report Share Posted May 31 2 hours ago, skidude2 said: Any update on this please as the ads are soooo annoying. How can I install AdBlock on android on the test version you provided ? Hi skidude2, have reported this issue and it will be added in the next version. Link to comment Share on other sites More sharing options...
TimTam Posted June 6 Report Share Posted June 6 (edited) On 5/24/2024 at 10:24 AM, BugSir009 said: Hi skidude2, https://www.viberate.com/ could you try out the attached test version? https://piktid.com/superid-ai-photo-enhancer/ mx_five_pre_m6_mx6_ceed328_22570_7.4.3.700_proguard_202405071606.apk 16.25 MB · 35 downloads Thanks for this! Edited July 16 by TimTam Link to comment Share on other sites More sharing options...
