MedMall Posted April 13 Report Share Posted April 13 NB! I cannot post in Russian forum!((( Не могу выбрать Русский форум при создании темы! Я не понимаю, почему. При клике мышкой нужный пункт не выбирается((( Проблема такая. Примерно около месяца назад перестали работать любые расширения управления громкостью типа "Volume Master". "Volume Booster" и т.п. В чём может быть дело? Maxthon Версия:7.1.8.6001(64 бит)0203 02:34 Браузер Maxthon нравится и меня устраивает, но без фичи управления громкостью он мне не нужен( Quote Link to comment
BugSir009 Posted April 15 Report Share Posted April 15 On 4/13/2024 at 7:11 PM, MedMall said: NB! I cannot post in Russian forum!((( I can't select Russian forum when creating a topic! I do not understand why. When you click the mouse, the desired item is not selected ((( The problem is this. About a month ago, any volume control extensions like "Volume Master" stopped working. "Volume Booster" etc. What can be wrong? Maxthon Version:7.1.8.6001(64 bit)0203 02:34 I like the Maxthon browser and am happy with it, but without the volume control feature I don’t need it( Hi MedMall, the development team is working on updating the chromium and this might be the reason why the extension is not working well. I tried to search for it and maybe you could add this extension which supports older browser : https://chromewebstore.google.com/detail/volume-master-outdated-br/fflcgbahhodkmllfoeldoiaemngpiphj Quote Link to comment
MedMall Posted April 15 Author Report Share Posted April 15 In my case "outdated" version not working too( But today I found one extension that works - "Volume Control". Thanks) Quote Link to comment
Join the conversation
