TheWhitestOfFangs Posted January 8, 2024 Report Share Posted January 8, 2024 Hi, I know you are working hard on V7 and the beta updates. The Android version really needs the ability to use an ad blocker. While I would be happy to use the same setup I use on my PC (uBlock Origin with custom settings), I understand that might not be an option right now - but any option is better than none. Please add this feature ASAP, it helps a lot! Link to comment Share on other sites More sharing options...
