Toh 阿杜 Posted September 13 Report Share Posted September 13 (edited) Youtube shorts and Pixiv website will always have the white piece cover on the page and don't know how to remove. Edited September 13 by Toh 阿杜 Quote Link to comment
BugSir009 Posted September 13 Report Share Posted September 13 4 hours ago, Toh 阿杜 said: Youtube shorts and Pixiv website will always have the white piece cover on the page and don't know how to remove. Hi Toh 阿杜, may I know what white piece cover are you referring to? And which version are you currently using? I tried to cross check in Chrome and it looks similar. Quote Link to comment
Toh 阿杜 Posted September 13 Author Report Share Posted September 13 Hi, here is the screenshot from other browser, you can see the different there. If normally, the Pixiv website will have all black color on the page if i use dark mode, not like the first picture that have white color cover a lot of part. And here, is also the same. Normally the bottom there will not have white color cover on it. For the version, im now using 7.1.6.1300 beta that i update yesterday. But this issue is actually occur since the last 3 or 4 version. Every time when i saw the update i was hoping it will fix this issue, but it's not, so i decided to post here and seek for help. Quote Link to comment
BugSir009 Posted September 13 Report Share Posted September 13 27 minutes ago, Toh 阿杜 said: Hi, here is the screenshot from other browser, you can see the different there. If normally, the Pixiv website will have all black color on the page if i use dark mode, not like the first picture that have white color cover a lot of part. And here, is also the same. Normally the bottom there will not have white color cover on it. For the version, im now using 7.1.6.1300 beta that i update yesterday. But this issue is actually occur since the last 3 or 4 version. Every time when i saw the update i was hoping it will fix this issue, but it's not, so i decided to post here and seek for help. Hi Toh 阿杜, could you try again with the latest 1700 version? Quote Link to comment
Join the conversation
