Kay Posted August 24, 2021 Report Share Posted August 24, 2021 1. When I middle-click a link, I like for it to open in a foreground tab. I know about Shift+middle-click opening a link in a new tab in the foreground, however it'd be good if there was an option, so that a middle-click opens the link in the foreground. Otherwise, it'd be good to add 'When you open a link in a new tab, switch to it immediately' option like Firefox. 2. How can I turn off Magic Fill? I don't want to save my passwords and keywords. Tip Give Link to comment Share on other sites More sharing options...
BugSir009 Posted August 25, 2021 Report Share Posted August 25, 2021 20 hours ago, Kay said: 1. When I middle-click a link, I like for it to open in a foreground tab. I know about Shift+middle-click opening a link in a new tab in the foreground, however it'd be good if there was an option, so that a middle-click opens the link in the foreground. Hi Kay, you could go to Settings < Tab < Always open new foreground tab when clicking link and select it. So once you click on any link, it will be open in the foreground. 20 hours ago, Kay said: 2. How can I turn off Magic Fill? I don't want to save my passwords and keywords. Currently we do not support the turning off of the feature. However in future versions, the development team will add in the option for users to turn it off if they wish to. Tip Give Link to comment Share on other sites More sharing options...
Kay Posted August 25, 2021 Author Report Share Posted August 25, 2021 I already set 'Always open new foreground tab when clicking link' option, but it doesn't work when middle-click a link. Tip Give Link to comment Share on other sites More sharing options...
BugSir009 Posted August 25, 2021 Report Share Posted August 25, 2021 1 hour ago, Kay said: I already set 'Always open new foreground tab when clicking link' option, but it doesn't work when middle-click a link. Hi Kay, for this command you just need to use the usual left click on the link and it should open in foreground. Tip Give Link to comment Share on other sites More sharing options...
