specialfx Posted June 24, 2017 Report Share Posted June 24, 2017 Hello please can anyone let me know how to change my maxthon homepage from US to UK version? Reason being the ebay tab in US version in USD Also the 5 day weather function does not load to finality,says loading all the time..... this is on Maxthon 3 and Maxthon 5 Maybe it is my old 32 bit HP laptop but all else functions just fine. I have tried uninstalling and reinstalling from google, to no avail. Is their a way to get these working please Many thanks in advance Link to comment Share on other sites More sharing options...
Artee Posted June 24, 2017 Report Share Posted June 24, 2017 By homepage do you mean http://i.maxthon.com/ ? It seems like it was just made that way. Forcing the UK version (http://i.maxthon.com/en-uk.htm) removes most of the bars on the side. So I guess there's no way for end users to make the eBay bar take info from UK version. As for the weather, maybe there's some extension or firewall rules that prevent the forecast from loading? Because it works fine on my end (5.1.0.1400) Link to comment Share on other sites More sharing options...
karajan Posted June 24, 2017 Report Share Posted June 24, 2017 i guess that if you want ebay uk, the way is to make a shortcut to ebay uk, display depends on your location for weather make your own shortcut to weather.com ( works on MX 5.1.0.1700 ) if doesn't work as artee said some rules side effects or a server latency Link to comment Share on other sites More sharing options...
7twenty Posted June 24, 2017 Report Share Posted June 24, 2017 I can't see any sort of ebay tab on i.maxthon.com (us or uk) Only thing is the small ebay button that is a link to the site. That can be changed to whatever country you want. 2 hours ago, specialfx said: Also the 5 day weather function does not load to finality,says loading all the time.... No issues here. Something might be blocking it from accessing the data. Test by turning off ABP (although the site is supposed to be exempt from being blocked) and any other firewall software. Link to comment Share on other sites More sharing options...
