IceHouse 45 Posted May 1, 2017 Report Share Posted May 1, 2017 Hi maxthon community, I am using now maxthon passport, I would like to put the shadow email in this forum but its doesnt work. I do not received confirmation into my real email. I am trying some times. Here the picture Works fine with the real email, no shadow. Tip Give Link to post Share on other sites
Max - Admin Bot - 4 Posted May 1, 2017 Report Share Posted May 1, 2017 The topic has been moved from Welcome! > Maxthon Newcomer to Product Support > Maxthon Support & Discussion. I'm your friendly bot Tip Give Link to post Share on other sites
BugSir006 1,203 Posted May 2, 2017 Report Share Posted May 2, 2017 Hi there, please check the UUMail "forward" status has been turned on the UUMail page. But it seems that you've already successfully registered. Or the uu.me in the pic is another account you registered rather than the one you use to post this thread? Tip Give Link to post Share on other sites
IceHouse 45 Posted May 4, 2017 Author Report Share Posted May 4, 2017 On 2/05/2017 at 3:16 AM, BugSir006 said: Hi there, please check the UUMail "forward" status has been turned on the UUMail page. But it seems that you've already successfully registered. Or the uu.me in the pic is another account you registered rather than the one you use to post this thread? Hi , I submitted you more information about me, I hope it will be of great help. thanks! Tip Give Link to post Share on other sites
BugSir006 1,203 Posted May 5, 2017 Report Share Posted May 5, 2017 21 hours ago, IceHouse said: Hi , I submitted you more information about me, I hope it will be of great help. thanks! Well received! Tip Give Link to post Share on other sites
Blinderson 14 Posted May 6, 2017 Report Share Posted May 6, 2017 I've been having the forwarding problem too.It worked a bit when i set it up, but hasn't since All are turned on for forwarding, too Tip Give Link to post Share on other sites
BugSir006 1,203 Posted May 8, 2017 Report Share Posted May 8, 2017 On 5/6/2017 at 0:09 AM, Blinderson said: I've been having the forwarding problem too.It worked a bit when i set it up, but hasn't since All are turned on for forwarding, too Hey Blinderson, please PM me your real email address and the shadow email address you got forwarding problems. I'll forward this info to our technicians to look up the issue. And if possible, better tell us what forwarding email you didn't receive, like register a forum or a shopping site. Tip Give Link to post Share on other sites
