GameDevGuy Posted September 9, 2016 Report Share Posted September 9, 2016 Here is a bug that results in the wrong site being shown, no matter which tab is selected after selecting a retracted tab. Please follow this recipe. (It has nothing to do with the specific sites in this example, pick any site you want, as long as there are enough to make retracted tabs.) 1. Open enough tabs so there is a retracted tab list. 2. Select one of the retracted tabs. 3. It becomes one of the visible tabs. Bug 1. The URL line is not the site clicked on, and is being viewed. 4. Select a different already visible tab. 5. Select the tab that was originally retracted. (The one that was selected in step 2.) 6. Select a different already visible tab. Bug 2. The tab selected is not the one shown, it is the one from Bug 1. 7. Select another different already visible tab. Bug 3. The site selected is not shown, and the contents are now stuck as the site from the URL of Bug 1. Now, no matter what tab is clicked on, the site will not change. I am using v5.0.1.1200. Hope you can fix this, as it is a major bug. Thanks, Scott. Tip Give Link to comment Share on other sites More sharing options...
Kreator-2 Posted September 11, 2016 Report Share Posted September 11, 2016 Is it like that? tsIs]s Tip Give Link to comment Share on other sites More sharing options...
BugSir006 Posted September 12, 2016 Report Share Posted September 12, 2016 Hi Scott, thanks for reporting! I can reproduce this bug on my device and I've forwarded it to our product team. Will tell you here once the bug been fixed. Thanks again Scott Tip Give Link to comment Share on other sites More sharing options...
GameDevGuy Posted September 13, 2016 Author Report Share Posted September 13, 2016 Hi BugSir006, Thank you for confrming the bug. Looking forward to it being fixed. Other than this issue, my experience with MX5 has been excellent so far. Scott. BugSir00 Tip Give Link to comment Share on other sites More sharing options...
GameDevGuy Posted September 27, 2016 Author Report Share Posted September 27, 2016 Hi, Thank you for the beta update. Downloaded the latest windows version (5.0.1.1700), and have still found that once there are retactable tabs, it is easy to end up in a state where the tab and url shown does not match the web page shown and odd things happen. For example: I consider this a major problem, and hope it is fixed before final release. Scott. Tip Give Link to comment Share on other sites More sharing options...
