Gabesz Posted February 8, 2016 Report Share Posted February 8, 2016 Many sites, for example the maxthon forum( ebay, etc) displayed incorrectly. See screenshot. In the normal versions the fonts are readable. Why? I try several Pc and laptop, the same resullt. The op Win 7 or Win10 Hungarian language. Link to comment Share on other sites More sharing options...
7twenty Posted February 9, 2016 Report Share Posted February 9, 2016 MX4.9 doesn't provide an option to select a default font, so the only thing i can think of is that it can't find the default font so is using a substitute instead. Can you check to see if your system has the Helvetica Neue, Helvetica, Arial fonts? Would be odd if all the systems you checked didn't have at least one of those fonts. Link to comment Share on other sites More sharing options...
Gabesz Posted February 9, 2016 Author Report Share Posted February 9, 2016 I checked, I have all the fonts, With the older version. 4.8.xxx there is no problem with the fonts, all sites looking good, only the the newer 4.9.xxx maxthon version have this. Link to comment Share on other sites More sharing options...
Magdalene Posted February 9, 2016 Report Share Posted February 9, 2016 It's a problem with Direct Write in the Blink engine (which the user can't change). The Devs have to switch it off in the "flags" or you have to wait for the core to be updated. Link to comment Share on other sites More sharing options...
Gabesz Posted March 1, 2016 Author Report Share Posted March 1, 2016 In 4.9.1.1000 thehre is still wrong look. Link to comment Share on other sites More sharing options...
