Jus2021 Posted December 26, 2015 Report Share Posted December 26, 2015 Thank you for your wonderful work. Since you introduce the version 4.9, I noticed that when I select "Tab up", there is no problem (see attached file: MaxthonSnap_1_cor.png) but when I select "Tab down", the tab remains at the top in this new (see attached file: MaxthonSnap_2_cor.png). This behaviour was not in the previous version. I am using windows vista. Am missing something? Thank in advance for your help Jus Link to comment Share on other sites More sharing options...
Tony Posted December 26, 2015 Report Share Posted December 26, 2015 seems they have not implemented it even though the option is there - its not difficult to get working - move a couple of lines of code in 0.dat after unpacking it moves the tabs under the taskbar but as an option may be a little more complicated - copy the enclosed file to the install dir and see if thats what you want - its either or at the moment back up the original 0.dat file and as ever all my skin mods come with the note that they have only been quickly tested - they wont trash anything but they may not be perfect 0.dat Tony - Vivaldi 4 on Windows 10 64Bit Link to comment Share on other sites More sharing options...
BugSir007 Posted December 28, 2015 Report Share Posted December 28, 2015 Hi, Thanks for reaching out. Tab down is not supported at the moment, it will be implemented in future version though. Please wait patiently. Thanks fro your support! Link to comment Share on other sites More sharing options...
Jus2021 Posted December 28, 2015 Author Report Share Posted December 28, 2015 Thank you Tony. I have tried your method. It is working. I just try to see if it is working also in putting back tab up but it does not. Anyway we will try again when the new version will be published as said BugSir. Jus Link to comment Share on other sites More sharing options...
