16506399 Posted October 26, 2015 Report Share Posted October 26, 2015 hello, can someone please tell me how to change the default search engine on maxthon for tabletsevidently it is set to yahoo by default and I would like to change it but can't see where to do itthank you very much Tip Give Link to comment Share on other sites More sharing options...
7twenty Posted October 26, 2015 Report Share Posted October 26, 2015 Don't use that version, but it's either in the options somewhere, or if the search providers icon shows in the address bar click that and it should give you other options. Tip Give Link to comment Share on other sites More sharing options...
slank Posted October 26, 2015 Report Share Posted October 26, 2015 You can change it from the drop down menu on the addrees bar. Tip Give Link to comment Share on other sites More sharing options...
Manasa Posted October 27, 2015 Report Share Posted October 27, 2015 thanks for suggestion Tip Give Link to comment Share on other sites More sharing options...
BugSir007 Posted November 6, 2015 Report Share Posted November 6, 2015 hello, can someone please tell me how to change the default search engine on maxthon for tabletsevidently it is set to yahoo by default and I would like to change it but can't see where to do itthank you very muchDid the suggestion above helped to fix your problem?Hope everything is fine now. Tip Give Link to comment Share on other sites More sharing options...
