GrandMOMZ Posted September 30, 2015 Report Share Posted September 30, 2015 I am on a tablet and I am having two problems that I hope someone can assist me with. On my Facebook, and some other sites, the pages are not showing properly. The pages are completely black with white print. (same with this forum site) The pages are not displaying as they should and all photos are black and white too. My sound for some reason can not be adjusted. My volume controls are for some reason adjusting the upAnd down of the pages. I am hoping this is only a settings issue but I don't know how to find the settings that I would need to adjust. Could someone please tell me how to do this or tell me what I need to do to correct this. Thankyou Link to comment Share on other sites More sharing options...
7twenty Posted October 1, 2015 Report Share Posted October 1, 2015 Check the options for page navigation, can't recall the name, but there is an option to use vol up/down to go page up/down.I'm assuming you're using MX for Android? Try disabling ABP and see if that helps. Link to comment Share on other sites More sharing options...
slank Posted October 1, 2015 Report Share Posted October 1, 2015 Settings > Page display > Quick Scroll By Volume > unselect Check that you don't have Nightmode enabled Link to comment Share on other sites More sharing options...
Manasa Posted October 5, 2015 Report Share Posted October 5, 2015 I am also facing the same problem thanks for suggestion Link to comment Share on other sites More sharing options...
BugSir007 Posted October 8, 2015 Report Share Posted October 8, 2015 Hi,May i know your tablet model and the version of android you are using on it? Link to comment Share on other sites More sharing options...
