problem with authentication by domain login name
Hi, i use maxthon in my company. The most sites load automatically using athenticaton by domain login name. Unfortunately maxthon has a problem with authentication and asks for login and password. For expample on IE it works fine. Could it be solved in any way?
br
Maciej
Hi and welcome to Forum... (^^,)
Have you set your Maxthon Settings > Magic Fill to Auto... ??
Then when you login to the webpage, that wont work so good. Try to Right-Click in the spaces, where you put in your codes > and use Fill Form in both boxes > and login.
To test it > logout  > and do a login again. > Double click in the first code box > and your mail / code turns up > press on it > then the login will work.
Best regards Ohke
P.S. If it don't work, then you have to remove the old Cookie for that page (via Developer tool > Resources > Cookies) and make a new login, as written above.
