Chorong761 Posted May 9, 2015 Report Share Posted May 9, 2015 Hi, when I use my android tablet or phone to login to "bbs.area-11.com", the captcha would always show as being incorrect but with other browsers like chrome it will not have this problem. Tip Give Link to comment Share on other sites More sharing options...
BugSir007 Posted May 11, 2015 Report Share Posted May 11, 2015 Hi, Thank you for reaching out and really sorry for this inconvenience brought to you. I wanted to help but unfortunately the site does not support ne registrations. If convenient, would you please provide us( via PM) with a registered account info to conduct a test? We'll be more than happy to help you. Meantime, i'll let our team know about this issue and try to investigate what could be causing this problem. Thanks. Tip Give Link to comment Share on other sites More sharing options...
joemax Posted May 11, 2015 Report Share Posted May 11, 2015 It is not necessary to log in, you can test the captcha without an account. It seemed to work well with lollipop 5.1.1 on Nexus 7 and JB4.1.1 JTE phone, both using Mx4.4.3.1000 b2917. Tip Give Link to comment Share on other sites More sharing options...
BugSir007 Posted May 11, 2015 Report Share Posted May 11, 2015 Hi Chorong761, I just test after joemax notified me that i don't need to have a registered account to test. It worked as expected after failing once... You may try again as well. Thanks joemax for your attention. Tip Give Link to comment Share on other sites More sharing options...
Chorong761 Posted May 11, 2015 Author Report Share Posted May 11, 2015 I've edited the image to reduce size ntz Tip Give Link to comment Share on other sites More sharing options...
