MarkStrobel3367 Posted January 13, 2015 Report Share Posted January 13, 2015 Today, I installed Maxthon browser on my laptop computer. I imported rss feeds from my AOL Reader account to the built in reader in Maxthon as an OMPL file. The feeds never imported however. Only the folders imported. Is there a problem with this reader? I can I fix the reader to accept the feeds? Thanks. Tip Give Link to comment Share on other sites More sharing options...
magg Posted January 13, 2015 Report Share Posted January 13, 2015 Did you try to click on this arrow marked on my screenshot? Tip Give Link to comment Share on other sites More sharing options...
MarkStrobel3367 Posted January 13, 2015 Author Report Share Posted January 13, 2015 I just noticed that the feeds are now in the folders. However, they have yet to update. When I clicked on the RSS Reader tab, several hours after I imported the feeds, it still reports that it is loading. Is this reader on the slow side? Tip Give Link to comment Share on other sites More sharing options...
magg Posted January 13, 2015 Report Share Posted January 13, 2015 MarkStrobel3367 replied at 2015-1-12 20:53 I just noticed that the feeds are now in the folders. However, they have yet to update. When I cli ... I just noticed that the feeds are now in the folders You can sort your feeds by drag&drop from folders. When I clicked on the RSS Reader tab, several hours after I imported the feeds, it still reports that it is loading. Try to click on "Update all" button and check also your internet connection . Tip Give Link to comment Share on other sites More sharing options...
MarkStrobel3367 Posted January 13, 2015 Author Report Share Posted January 13, 2015 I clicked on 'Update All'. A message appears that it is updating. However, nothing is happening. Tip Give Link to comment Share on other sites More sharing options...
MarkStrobel3367 Posted January 13, 2015 Author Report Share Posted January 13, 2015 The reader still hasn't updated any feeds after importing the feeds several hours ago after clicking on 'Update All'. Tip Give Link to comment Share on other sites More sharing options...
magg Posted January 13, 2015 Report Share Posted January 13, 2015 MarkStrobel3367 replied at 2015-1-12 21:03 I clicked on 'Update All'. A message appears that it is updating. However, nothing is happening. Try to update your feeds one-by-one. Right click on feed and select "Update". Tip Give Link to comment Share on other sites More sharing options...
MarkStrobel3367 Posted January 13, 2015 Author Report Share Posted January 13, 2015 Thank you for your suggestions. However, if I need to update the feeds one at a time, I might as well stay with the AOL Reader. Perhaps I have more feeds than what this built in reader can take. Tip Give Link to comment Share on other sites More sharing options...
MarkStrobel3367 Posted January 13, 2015 Author Report Share Posted January 13, 2015 I just checked the firewall and everything is fine. If the feeds don't update tomorrow morning, then I will remove one folder at a time to see if that makes a difference. My guess is that I have more feeds than what this reader can take. However, I have had no problems importing this list with other free readers. Tip Give Link to comment Share on other sites More sharing options...
MarkStrobel3367 Posted January 13, 2015 Author Report Share Posted January 13, 2015 This morning, I reduced the number of folders to one that contained around 20 feeds. It was at this point when the reader began to update the feeds. Even then, the updating process wasn't consistent. Additionally, one of the Maxthon files began to exhaust my computer CPU's. I believe that this file is directly related to the built in RSS Reader. Unless this built in reader is improved, I don't want to reduce my number of feeds to accommodate. I would rather stick with the AOL Reader. It would be nice if there was an AOL Reader addon that I could use with this browser. Tip Give Link to comment Share on other sites More sharing options...
magg Posted January 13, 2015 Report Share Posted January 13, 2015 MarkStrobel3367 replied at 2015-1-13 09:55 This morning, I reduced the number of folders to one that contained around 20 feeds. It was at this ... Hi there. If you want - you can try my AOL Reader extension. Simply download extension from my attachment, install it and (I hope) enjoy of feeds reading AOL_Reader.mxaddon Tip Give Link to comment Share on other sites More sharing options...
MarkStrobel3367 Posted January 13, 2015 Author Report Share Posted January 13, 2015 Thank you so much! This add on is perfect! Tip Give Link to comment Share on other sites More sharing options...
magg Posted January 13, 2015 Report Share Posted January 13, 2015 MarkStrobel3367 replied at 2015-1-13 14:15 Thank you so much! This add on is perfect! Glad you like it. Later I try to make some modifications for better browsing/ reading. Tip Give Link to comment Share on other sites More sharing options...
MarkStrobel3367 Posted January 13, 2015 Author Report Share Posted January 13, 2015 I think that it is perfect now! Tip Give Link to comment Share on other sites More sharing options...
magg Posted January 14, 2015 Report Share Posted January 14, 2015 If anyone would be interested Feedly RSS Reader extension is also available . Like before- download my attachment and install it.feedly.mxaddon Tip Give Link to comment Share on other sites More sharing options...
MarkStrobel3367 Posted January 14, 2015 Author Report Share Posted January 14, 2015 For some reason, when I restarted Maxthon, the AOL extension was gone from the left column. I needed to reinstall it. This was the only extension that disappeared from the column. Do you know why this happened? Thanks. Tip Give Link to comment Share on other sites More sharing options...
magg Posted January 14, 2015 Report Share Posted January 14, 2015 MarkStrobel3367 replied at 2015-1-13 19:56 For some reason, when I restarted Maxthon, the AOL extension was gone from the left column. I neede ... Are you logged to your Maxthon Passport? Anyway try to download once again this extension and install it (I have made some modifications). Now it should works fine. Tip Give Link to comment Share on other sites More sharing options...
MarkStrobel3367 Posted January 14, 2015 Author Report Share Posted January 14, 2015 Thanks, Magg. I have been logged into the Passport. I reinstalled it. I will let you know if it disappears again. Tip Give Link to comment Share on other sites More sharing options...
MarkStrobel3367 Posted January 14, 2015 Author Report Share Posted January 14, 2015 magg replied at 2015-1-13 20:03 Are you logged to your Maxthon Passport? Anyway try to download once again this extension and inst ... Magg, I have a question for you - Is there any way to design the aol extension so that one doesn't have to manually log in each time the browser restarts? I use LastPass for my login info. Unfortunately, aol reader doesn't allow users to stay logged in. Thanks. Tip Give Link to comment Share on other sites More sharing options...
magg Posted January 14, 2015 Report Share Posted January 14, 2015 MarkStrobel3367 replied at 2015-1-13 20:56 Magg, I have a question for you - Is there any way to design the aol extension so that one doesn't ... To be honest- I'm a noob in creating extensions. Second thing- Aol Reader probably doesn't support autologin and doesn't accept cookies. You can check easily with any other browsers-logg into AOL Reader then close/restart browser and you have to loggin again to the reader. Even when you don't clear cookies. FYI-my Feedly rss have autologin/ keep cookies... So far- I'm realy sorry-but I can't help you to solve this issue. Maybe someone on forum could help with this. My advice- try once again Maxthons RSS reader or try Feedly. Tip Give Link to comment Share on other sites More sharing options...
MarkStrobel3367 Posted January 14, 2015 Author Report Share Posted January 14, 2015 I think that your aol reader extension works fine regardless of the login issue. By the way, your extension appeared in the browser after restarting. Thank you so much for sharing this with me! Tip Give Link to comment Share on other sites More sharing options...
