Please help me to resolve this problem
Posted
I'd try reinstalling.
The language file isn't working as it should. Try selecting another language from Menu > language. Then go back to your default language.
Not sure about the other error? when does it occur?
Posted
They occur today, only about some hours ago. They're dealt after I follow your guideline.
Second error often appear when I open a new tag. I don't know the reason...
Posted
I don't know the reason, but Maxthon fixed these errors automatically after I had restarted my PC. But I still want to know exactly what happened, because I don't know when they'll occur again.
By the way, Maxthon doesn't display some special characters. Can you help me?
Posted
1st : probably a corrupted file
2nd : try to use unicode utf-8 in tools (encoding
)encod.thumb.png.9cdd290608252e31f92854ae
Posted
I'm using UTF-8 :(
Some characters display normally, others become squares :(
Posted
Maxthon has some issues with some special characters/emoji. Has been mentioned before. Was also mentioned it will be looked into IIRC.
Much of the characters on this wikipedia page don't work, but display fine in other browsers. (Edge/Chrome/Opera all display monochrome / FF in colour).
Not sure if it's because MX is still using an older blink core (v39) or there's something else that's missing/not implemented. Doesn't seem to be high on the to do list though.
Interestingly if you copy a link from that page (eg. whale emoji) and use the paste & go command then you will see the correct emoji in the address bar (only black&white), yet it doesn't display on the page?!
Posted
confirmed ! but works fine in retro.....
retro.thumb.png.3a467ffcc13b092e01a3ef5bultra.thumb.png.3ce9d60274690d8abe94aa52
