ioosis Posted August 29, 2015 Report Share Posted August 29, 2015 plz iam stuck on both viewing method can not download Link to comment Share on other sites More sharing options...
7twenty Posted August 30, 2015 Report Share Posted August 30, 2015 It doesn't like Maxthon in the User Agent. Choose any of the other options it will work. Also works in Retro for me with the default UA. What version of IE do you have installed? Link to comment Share on other sites More sharing options...
ioosis Posted August 31, 2015 Author Report Share Posted August 31, 2015 i use edge win10 b10240 Maxthon in the User Agent Link to comment Share on other sites More sharing options...
7twenty Posted August 31, 2015 Report Share Posted August 31, 2015 i use edge win10 b10240 Maxthon in the User Agent Yes, should've noticed you were on win10. As above, test with removing Maxthon from the UA or choose one of the other options. As to why it's not working in Retro is weird, but unless some others can also test I can only guess it's a local issue. Try cleaning cache and see if that helps. Link to comment Share on other sites More sharing options...
