neocrescent Posted May 27, 2015 Report Share Posted May 27, 2015 Hello! This is my first post here. I tried reporting this problem through the email that was posted on the contact page on the maxthon website but no one was even trying to answer my mails. and so here i am posting the problems i am experiencing with this browser. -scroll bar when i am reading something, while holding the scroll bar it just shoots up or down sometimes. and im not even pressing the page up or page down keys. -flash player when opening the browser sometimes it tells me that i need to install flash player. how can this happen when i've already installed the latest flash player on my system. -page refresh switching between tabs sometimes causes one or almost all opened tabs to refresh itself. -loading sluggish just opening any website sometimes is taking too long to load. after experiencing this i tried using another browser (chrome) and it had no problem opening the site. Link to comment Share on other sites More sharing options...
neocrescent Posted May 27, 2015 Author Report Share Posted May 27, 2015 im using windows 7 starter. latest version of maxthon the maxthon v.4.4.5.1000 Link to comment Share on other sites More sharing options...
7twenty Posted May 27, 2015 Report Share Posted May 27, 2015 For the Flash issue read through the flash thread. For the other things, go through the troubleshooting thread. Probably related to an extension or ABP. How many tabs do you normally have open? Link to comment Share on other sites More sharing options...
neocrescent Posted May 27, 2015 Author Report Share Posted May 27, 2015 3 to 4 tabs For the Flash issue read through the flash thread. For the other things, go through the troubleshooting thread. Probably related to an extension or ABP. How many tabs do you normally have open? 3 to 4 tabs. sometimes 6. Link to comment Share on other sites More sharing options...
7twenty Posted May 27, 2015 Report Share Posted May 27, 2015 Ok, well probably not memory related. I'd be going through the threads mentioned. Hopefully you can come back to us with some more info based on what you find doing that. Or even better a fix. For a quick test, if you use a Passport account, try logging out and see if the same thing happens. Link to comment Share on other sites More sharing options...
neocrescent Posted May 29, 2015 Author Report Share Posted May 29, 2015 Is it a fresh install or an update of successive old versions? Is it a fresh install or an update of successive old versions? not a fresh install. just update from a old version, i think i was using the previous version before v4.4.5.1000. btw, i forgot to mention this - maxthon sometime crashes for no reason. just now as i was playing a web browser game it crash several times. Link to comment Share on other sites More sharing options...
neocrescent Posted May 29, 2015 Author Report Share Posted May 29, 2015 Therefore I encourage you to perform a clean install. ok thanks. do i always have to do clean install every time there's a new version update? Link to comment Share on other sites More sharing options...
neocrescent Posted May 29, 2015 Author Report Share Posted May 29, 2015 No, but if for example you don't have performed since old version with ad hunter, it's better. ok. i'll do a clean install later. hopefully some of the problems will be gone. Link to comment Share on other sites More sharing options...
BugMiss006 Posted June 3, 2015 Report Share Posted June 3, 2015 Hi, Thanks for your question. You can upgrade to our latest version here http://forum.maxthon.com/index.php/topic/15204-maxthon-cloud-browser-for-windows-v4452000-official-released/?p=82993.anddo a clean install to see if the problem persists. If it still does not work, feel free to contact us. Link to comment Share on other sites More sharing options...
