Chemodan
resolved Default search engine
11 posts in this topic
Posted (edited)
Привет!
Есть старый баг. Если в Maxthon использовать поиск от kinopoisk.ru, то в результате запроса на кириллице сайт показывает ошибку. Это повторяется от версии к версии, только в Maxthon. Это не зависит от режима, баг проявляется в режиме ретро и в режиме ультра. Очень хочется чтоб разработчики исправили эту ошибку. Строка поиска для всех браузеров выглядит так: https://www.kinopoisk.ru/index.php?first=no&what=&kp_query=%s
Translation from Google:
Hello!
There is an old bug. If you use search in Maxthon from kinopoisk.ru, then as a result of the query in Cyrillic the site shows an error. This is repeated from version to version, only in Maxthon. It does not depend on the mode, the bug is shown in retro mode and in ultra mode. I'd like it so that the developers have corrected this mistake. The search string for all browsers looks like this: https://www.kinopoisk.ru/index.php?first=no&what=&kp_query=%s
Here is the search string in browsers:
Opera 45
Opera 12.18
Vivaldi 1.10
Internet Explorer 11
Edited by Chemodan
Hi, I can't reproduce your issue. Kinopoisk works ok in MX5 and it worked fine in maxthon 4.4 and 4.9. I suppose you have some encryption or font issues. May be some changes in web page font settings could help.
Posted (edited)
This is strange. Incorrectly works only in the Maxthon browser. I also gave an example of other browsers. No settings with fonts have ever been performed. It was earlier in Windows XP and it is now in Windows 7. So I do not know where else to look for the cause.
And it's not in the fonts. Because the site gives the answer: Unfortunately, your search did not match any documents. This means that Maxthon initially interacts incorrectly with the site. I'll put it now on Windows 8.1 and look there.
Edited by Chemodan
I mean font settings in browser, not in your system.
Most likely the case is in character encoding. Look at the search bar in your screenshot. Look at the search for other browsers. And now look at the search line in Maxthon from me. I do not know how to fix this. Changing the encoding in the browser settings affects the entire site and does not correct the error in the search box.
P.S. In Windows 8.1 is the same :(
Лень читать, но краем глаза заметил поисковую строку...
Попробуй %us вместо %s. Это из-за кодировки.
Кстати, если сделать скрипт для поиска и загнать его в расширение, то работает всё нормально.
P.S. Если не поможет, пиши. Почитаю...
Posted (edited)
Да, кодировка. Только что просто стёр из строки последние  %s и всё стало нормально :) Умная мысла приходит опосля... на всякий случай прописал %us , спасибо, A.S. Но всё же странно, что клинило только в МX
Problem resolved, thanks to those who tried to help ;)
Edited by Chemodan
Надо прописать %us. Без этого может глючить. По-моему, у MX все вшитые поисковики так прописаны.
А вот DuckDuckGo в старых версиях даже с %us выдавал иероглифы, только из расширения нормально работал.
1 person likes this
Дописал. на всякий :) спасибо ещё раз!
