Give a tip
Better documentation for creating extensions with example
30536114
 Share
I was searching for the documentation of how to create an extension . If there was a simple tutorial available for the same that would help a lot(take it as a suggestion). Also the SDK hasn't been updated for over a year, I was curious if that's out of date ?
  • Like 1
Tip   Give
I've been on to them about creating a more user friendly info area for the extension API's with examples. Not on their plans though.
A.S's guides are a good start. Explains well how to put together a few types of extensions. Unfortunately the only other option is in the SDK documentation especially for details on how to use the API's, which the info can be a little vague (at least for me). Probably OK if you have more knowledge with coding.
Tip   Give
 Share
