PatchwerkQWER Posted November 20, 2015 Report Share Posted November 20, 2015 Hi I have problem with Maxthon (version: v4.4.8.1000). Some special characters (emoticons) doesn't show correctly. Here is compare with Chrome https://ctrlv.cz/DR3x (left side = maxthon) Encoding is on auto detect and "UTF 8". So I don't know where is the problem. It's really annoying. What I do wrong? Thanks for any help. Cheers Tip Give Link to comment Share on other sites More sharing options...
7twenty Posted November 20, 2015 Report Share Posted November 20, 2015 Known issue, but I can't find the older thread that it's being discussed in. What language are you using? Tip Give Link to comment Share on other sites More sharing options...
PatchwerkQWER Posted November 21, 2015 Author Report Share Posted November 21, 2015 I use czech language. But same problem with english. Cheers Tip Give Link to comment Share on other sites More sharing options...
7twenty Posted November 21, 2015 Report Share Posted November 21, 2015 Just had a bit of a look into this and it seems that it may be related to the old version of Blink that Maxthon uses. Older versions of other browsers also have the same issue, but updating to a more recent version resolves the issues. I'd say that until the core update is done then this won't be fixed. Hopefully not too much longer. Tip Give Link to comment Share on other sites More sharing options...
PatchwerkQWER Posted November 21, 2015 Author Report Share Posted November 21, 2015 Oh, thanks. Maxthon is best This screenshot is evidence. https://ctrlv.cz/D6eQ Cheers (so, probably lock) Tip Give Link to comment Share on other sites More sharing options...
