mb007inc Posted October 26, 2015 Report Share Posted October 26, 2015 when I have a few tabs open with different sites open and then try and go between the tabs back and forth, the tabs keep closing, when I click on the tab(No where near the x by the way). I have to constantly keep pressing the "Restore last closed page" button to re open the tab. Is anyone else getting this problem ? My browser is v4.4.6.1000 and according to the browser update check is the latest and up to date ? Link to comment Share on other sites More sharing options...
QIK5L Posted October 26, 2015 Report Share Posted October 26, 2015 latest release, if that don't help what is your OS, links to pages that close ( to make sure not website crashing ) Link to comment Share on other sites More sharing options...
mb007inc Posted October 26, 2015 Author Report Share Posted October 26, 2015 My OS is Windows 10. Websites are fine. It can Facebook, Twitter, YouTube, My own site. It doesnt do it on any particular sites it does it on all different websites Link to comment Share on other sites More sharing options...
7twenty Posted October 26, 2015 Report Share Posted October 26, 2015 Check your settings under Settings > Tab bar > Close tab. Make sure that both options are unchecked and see if it still happens. If disabling them fixes it then it's the way the mouse is registering the clicks - adjust the settings for doubleclick, or change from using Rightclick. Link to comment Share on other sites More sharing options...
7twenty Posted October 27, 2015 Report Share Posted October 27, 2015 Reply from mb007inc via PM (can't post for some reason)Hi. I just wanted to say thank you for your assistance on the forum. I followed your advice and saw that the check box for double click to close tab was enabled. I thiink my mouse maybe producing a double click on one press, so that would explain the problem. I no longer seem to be getting this issue after your advice. Kind RegardsMartyn Link to comment Share on other sites More sharing options...
QIK5L Posted October 27, 2015 Report Share Posted October 27, 2015 I have both options unticked and just use the the wheel button for closing tabs. Link to comment Share on other sites More sharing options...
7twenty Posted October 27, 2015 Report Share Posted October 27, 2015 I have both options unticked and just use the the wheel button for closing tabs.You're using your mouse driver settings to do that i'm guessing, as there's no option for middle click in the gestures or shortcut keys? Link to comment Share on other sites More sharing options...
QIK5L Posted October 27, 2015 Report Share Posted October 27, 2015 I'm pretty sure that's the default setting for windows. Link to comment Share on other sites More sharing options...
7twenty Posted October 27, 2015 Report Share Posted October 27, 2015 Huh, well there you go, just tested and it works. Never knew that. And here i was wasting my time and clicks doing double left click!Weird that I can't find a setting for it anywhere in mouse settings though? Link to comment Share on other sites More sharing options...
QIK5L Posted October 28, 2015 Report Share Posted October 28, 2015 And if you wheel click in a spare space in a folder it will select all. Link to comment Share on other sites More sharing options...
slank Posted October 28, 2015 Report Share Posted October 28, 2015 Middle click will close a tab regardless of browser. The problem the OP is having is probably the result of a defective mouse or out dated drivers. Link to comment Share on other sites More sharing options...
7twenty Posted October 28, 2015 Report Share Posted October 28, 2015 And if you wheel click in a spare space in a folder it will select all.Can't get that to work in Win10.Middle click will close a tab regardless of browser. The problem the OP is having is probably the result of a defective mouse or out dated drivers.Looks like a mouse problem seeing as disabling that option has fixed it. Or possibly the way MX is detected the double click, a test in another browser would be interesting to see. But it seems the OP is happy with that fix. Link to comment Share on other sites More sharing options...
QIK5L Posted October 28, 2015 Report Share Posted October 28, 2015 Works on both of my Win 10 machines. Link to comment Share on other sites More sharing options...
