Scrummer Posted October 11, 2015 Report Share Posted October 11, 2015 not being able to use full screen function for videos on three sites. Link to comment Share on other sites More sharing options...
7twenty Posted October 11, 2015 Report Share Posted October 11, 2015 Which sites?Links?Not sure if you're after help or just trying make known an issue. But either way with nothing to test it makes it hard to do either. Link to comment Share on other sites More sharing options...
Scrummer Posted October 13, 2015 Author Report Share Posted October 13, 2015 animefreak.tvanimeshow.tvgogoanime.tvare three of my five main sitescricfree.tvHave not tried to use youtube because of these four problems. Link to comment Share on other sites More sharing options...
7twenty Posted October 13, 2015 Report Share Posted October 13, 2015 So what happens when you press the fullscreen button?I tried about 4 videos on two of those sites and had no issues. Press play, video starts, press fullscreen, works as intended.All were flash video, not sure if there's any HTML5 anywhere which may be different.But again, some more info is required to determine where the issue my be. Does it go fullscreen but not play? Doesn't play properly? Black screen? Nothing happens when pressing the fullscreen button? Button isn't available?Try going through the troubleshooting thread and see if that helps. Link to comment Share on other sites More sharing options...
