7twenty Posted September 18, 2015 Report Posted September 18, 2015 Hopefully someone with some more knowledge of the skin system might be able point me in the right direction. I want to change the control box in MX4 to match the style of Windows10, but the area in 10 has been widened slightly which is larger than what the default is in MX. Looking through all the code I can't see anything that would change it. The boxes and hitzones are correct, but when the tabbar is full there is an overlap of the last tab and the minimise button.
SnowLeopard Posted September 20, 2015 Report Posted September 20, 2015 (edited) Hopefully someone with some more knowledge of the skin system might be able point me in the right direction. I want to change the control box in MX4 to match the style of Windows10, but the area in 10 has been widened slightly which is larger than what the default is in MX. Looking through all the code I can't see anything that would change it. The boxes and hitzones are correct, but when the tabbar is full there is an overlap of the last tab and the minimise button. There are several ways to make room for the window controls.1. Unpack the skin2. In main you can enter this in skin.css .tabbar .max-spacer{ display: block; width: 120px;}It will overwrite an entry in tabbar > index.css. The value 120 is one I've seen used, but you can adjust it as needed.Or you can enter this in skin.css in the main foldertabbar-container { flow: horizontal; width: 100%%; height: 100%%; margin-left:-5px; padding-right:80px;}This overwrites an entry in tabbar > conntainer.css. The immportant value is padding-right. Note here 80px is specified. Adjust as nneeded.3. Repackage skin.I have used both methods in some skin mods with success.<<SL>> Edited September 20, 2015 by SnowLeopard 3
7twenty Posted September 21, 2015 Author Report Posted September 21, 2015 Thanks for the reply.Got it fixed over the weekend from a PM from tony while the forum was read only. He mentioned the tabbar/index.css and I found the max-spacer entry which I seemed to have looked over when looking previously. Changed it and it works great.
SnowLeopard Posted September 21, 2015 Report Posted September 21, 2015 Thanks for the reply.Got it fixed over the weekend from a PM from tony while the forum was read only. He mentioned the tabbar/index.css and I found the max-spacer entry which I seemed to have looked over when looking previously. Changed it and it works great.Yeh, I know; I did the experiment AFTER telling you what to do ... that's b... ackward ... but theory proved right.<<SL>>
