Rei Posted July 15, 2015 Report Share Posted July 15, 2015 So I've the latest version of Adobe on my Mac OS X, but every time I open a page a page which requires flash, it says that my Adobe Flash Player was blocked because it was outdated with the option to run it or update it again(but why would I? I already updated!) Any resolutions to this? Link to comment Share on other sites More sharing options...
lostinohio Posted July 15, 2015 Report Share Posted July 15, 2015 I am having the same issue, uninstalled and reinstalled and get same message, flash blocked... this is my go to browser and now it is becoming just a headache..... is this a mac, maxthon or flash issue? Link to comment Share on other sites More sharing options...
lostinohio Posted July 15, 2015 Report Share Posted July 15, 2015 after a bit if digging when i go to change flash settings it shows version 11.9.900.152 which is wrong because i have 18.9.9.209 installed and that is what shows in other browsers.question is why does this only happen on maxthon? does not happen on windows pc any help is appreciated Link to comment Share on other sites More sharing options...
mehmetki Posted July 16, 2015 Report Share Posted July 16, 2015 First, you have to uninstall the old version of flash. Then install new version. Uninstaller is on ''adobe lab'' Link to comment Share on other sites More sharing options...
backfolder Posted July 16, 2015 Report Share Posted July 16, 2015 Hi Rei and all. This worked for me: 1.- Check which version you have: System preferences -> Flash Player -> Updates. You should see Versión 18.0.0.209 plugin NPAPI and PPAPI. If you don´t have then go step 2. If you have go to step 3. 2.- Download Flash player: Step 1: Mac OS X 10.6 - 10.10. Step 2: F 18 Mac for Opera and Chromium PPAPI. File should be "install_flash_player_osx_ppapi.dmg". Of course you need to have installed "install_flash_player_osx.dmg". 3.- Access to plugins writing in URL bar "maxthon://plugins/" (without quotes) and click +Details (in the top right corner) and check for Adobe Flash Player. In my case there are 2 files (with respective version number). A.- PepperFlashPlayer.plugin | PPAPI (type) <-- OLD B.- Flash Player.plugin (located in /Library/Internet Plug-Ins/) | NPAPI (type) <-- NEW So, disable the A one, and check Allow Always in order to force system and maxthon to use B plugin. Maybe it´s good idea to restart your system. Link to comment Share on other sites More sharing options...
lostinohio Posted July 19, 2015 Report Share Posted July 19, 2015 Thanks backfolder for the fix..... happy camper now!! Link to comment Share on other sites More sharing options...
CatnipTARDIS Posted December 28, 2015 Report Share Posted December 28, 2015 With the same issue, albeit months later with versions 12.0... and 20.0... both installed, the fix worked for me as well. Link to comment Share on other sites More sharing options...
