Golfmann
Issue with Netflix Browse
6 posts in this topic
When I click on the details in Netflix, even though I use English language and always have, the pop up for movie details contains a Chinese character at the bottom and the whole layout is not correct...
See picture:
Make sure you haven't changed the Webpage Font option in settings > Advanced.
Another user had a similar issue and that was the problem.
Still the same I've used for years (tahoma) and western encoding...
I tried back to default as well.
Same thing on Netflix.
everything else is normal.
What happens if you set it to default?
Hi,
Can you give us a specifc address? then we can test it directly, besides, will you encounter the same problem when you are usring other browsers ?
thanks for your feedback .
