bug angel010
new [SDK] Maxthon Extension Development Guide & Package Tool | 2015/05/21
1 post in this topic
Here we offer the Maxthon Extension Development Guide and Packaging Tool (for Maxthon3, Maxthon Cloud Browser and Maxthon5).
English Maxthon Extension SDK
Update date:May 21, 2015
SDK runtime version:1.0.6
SDK document version:1.2.7
Mx-Extension-SDK.doc
Changelog:
1.2.7:
 - update stopOnClose
1.2.6:
- add contextmenu api
- add resize api
- add toolbar support
1.2.3:
- Update the description of def.json
1.2.2:
- Describe the objects that runtime.post support to post
1.2.1:
- The included JS File's format must be UTF8 with BOM
Maxthon Extension/Skin Packaging Tool
Update date:March 13, 2013
Version:1.0.7
MxPacker.rar
Instructions:
Pack: Drag the extension/skin directory onto the MxPacker icon (no need to run it) to make a package.
Unpack: Drag a package onto the MxPacker/skin icon (no need to run it) to unpack it.
or
Double click the MxPacker icon to run it, and pack or unpack a package using the GUI.
Note: Please rename the packed file's extension to .mxskin, if it is a skin file.
Examples:
These are from Maxthon Chinese BBS. So you may just take a look at it if your like.
Douban Radio: douban.fm.zip
Baidu Ting: baidu.ting.zip
Douban Radio and Baidu Ting are two popular apps in China which may offer you songs randomly. They can remember your taste and recommend the styles you like. Hope you enjoy.
Mx-Extension-SDK.zip
4 people like this
