Posted
Hello:
I am using Win 10 Pro Maxthon Version 7.3.1.4800 (64 bit) 0421 20:27.
When I delete a link from the Favorites in Max Note, I cannot see this deleted link in the trash can in the lower left corner. The trash can is always empty. Thanks
Posted
On 4/26/2025 at 10:33 PM, Toros37 said:
Hello:
Hi Toros37, sorry for missing out on your post. Could you try on the latest 5000 version and see if same issue occurs?
Posted
Hello BugSir009
Thank you very much for your answer.
I installed the latest version Maxthon Version 7.3.1.5000. But the problem persists. I am sending you the photos.
Unfortunately, the recycle bin appears empty. However, there were links that I deleted.
Good work. Thank you.
Posted
19 hours ago, Toros37 said:
Hello BugSir009
Hi Toros37, did you experience any syncing error?
