Problems Maxthon PC 7.3.1.1700 Portable beta x64
migel
Posted
Hi,
Today I tried the latest portable version (7.3.1.1700 (64-bit) 1212 08:56) on win x64 Ent, without the backup of my "user data" folder and also without any extensions.
The problems I mentioned before apply, namely:
1. Gmail disconnects for no reason (it asks me to log in again)
2. TRANSLATION WORKS WHENEVER IT WANT (right click/translate)
3. Another annoying problem I have is when I make a shortcut (in desktop) from any page Maxthon asks me (no matter what option I click)
    and creates an installation in Programs and Features\Installed Programs (pic 1)
This was not there in previous versions and is very annoying.
4. I still see the unspecified days the first time I open the new tab in maxthon
    I need to open a new tab page because I saw Continuous check-in for 0 days
    if I open an incognito page the selected one works fine e.g. Continuous check-in for 6 days (pic 2)
None of the above fixed it.
Thanks.
Posted
Hi migel, could you try the installed version and see if these issues persist?
Have reported this to the development team and they will try to optimize it.
Could you send the screenshot showing the unspecified days? Similarly kindly try and see if you encounter same situation in installed version.
Posted
Hi.
1+2. I have try with installed clean version also and with my USER DATA folder and nothing, the problem continued gmail and other disconnected every time.
3. Thanks, and I also saw that it creates more shortcuts at the start menu of windows from every shortcut i made with maxthon.
4. Pic1 is open normal new tab Maxthon
    Pic2 is open anonymous new tab
    the same in installed version.
A new problem (for me) that I discovered is that the shortcuts have gone back to the old way, i.e. they are encrypted (i.e. they do not open in any other explorer except Maxthon). In previous versions, the shortcuts were normal and opened with any explorer (Pic3).
