Maxthon PC 7.3.1.1600 beta
BugSir009
+ Added root directory option for Maxnote save directory selection.
* Updated multilingual translations.
- Fixed an issue where extensions could not be deleted.
- Fixed an issue where cookies could not be deleted.
- Fixed an issue where passwords could not be restored, causing them to disappear.
- Fixed an issue with delayed loading of third-party skins.
- Fixed an issue where the startup page was not set as the settings page.
- Fixed an issue where some mouse gestures did not work.
- Fixed an issue where the video popup-window could not go full screen.
- Fixed known crashes.
https://github.com/maxthon/Maxthon/releases/download/7.3.1.1600/maxthon_7.3.1.1600_beta_x64.exe
https://github.com/maxthon/Maxthon/releases/download/7.3.1.1600/maxthon_7.3.1.1600_beta_x86.exe
https://github.com/maxthon/Maxthon/releases/download/7.3.1.1600/maxthon_portable_7.3.1.1600_beta_x64.zip
https://github.com/maxthon/Maxthon/releases/download/7.3.1.1600/maxthon_portable_7.3.1.1600_beta_x86.zip
Maxthon PC 7.3.1.1400 beta
+ Added a new setting to exit the browser when closing the last new tab.
* Optimized post-installation directory size to 400MB.
- Fixed an issue where resource sniffer failed to download resources.
- Fixed an issue with pinned tab logic errors and gestures unable to unpin tabs.
- Fixed an issue where the video popup-window could not be dragged for split-screen and the keyboard arrow keys could not control video progress.
- Fixed an issue where video tool buttons were not displayed.
- Fixed an issue where the restored tab order was incorrect upon browser startup.
- Fixed an issue where the skin color did not follow the system theme changes.
https://github.com/maxthon/Maxthon/releases/download/7.3.1.1400/maxthon_7.3.1.1400_beta_x64.exe
https://github.com/maxthon/Maxthon/releases/download/7.3.1.1400/maxthon_7.3.1.1400_beta_x86.exe
https://github.com/maxthon/Maxthon/releases/download/7.3.1.1400/maxthon_portable_7.3.1.1400_beta_x64.zip
https://github.com/maxthon/Maxthon/releases/download/7.3.1.1400/maxthon_portable_7.3.1.1400_beta_x86.zip
  • Like 1
  • Thanks 3
When Maxthon is open, links from other programs are not launched.
You cannot delete cookies for a selected site in the menu => settings...
Maxthon does not import passwords from a selected local account, an attempt
to import deletes the current password list :(
The above deficiencies were already in previous versions 7.3... and they are still :(
  • Like 1
Hi Refix2, did you do a clean install for this new version?
8 hours ago, grisp1 said:
Hello @BugSir009
When closing a tab with 150+ tabs open, all the remaining tabs disappear for several seconds from the tabs area, then they come back.
Thanks.
Hi grisp1, bug reported.
8 hours ago, Magdalene said:
History page closes immediately after opening.
Hi Magdalene, we could not reproduce this issue on our end. Is there a possibility that one of your extension is causing this problem?
Maxthon 7.3.1.1500
Changelog:
https://github.com/maxthon/Maxthon/releases/tag/7.3.1.1500
Edited by alexzhus
  • Like 1
  • Thanks 2
Yes, I tried a clean install and the only thing I got was opening links from other programs in Maxthon.
Importing passwords deletes the current list but does not download a new one :(
Cookies for a selected site also cannot be deleted :(
  • Like 1
Key Updates
Added a new setting to exit the browser when closing the last new tab. New
Others
Update counts:16
  • Like 1
Hi Refix2, did you select the default file type to open in maxthon?
Have reported this error to the development team for further checking
  • Like 1
After a clean install, links opened without a problem, but due to the loss of passwords after an unfortunate Maxthon error, I restored the passwords by copying the entire folder from my backup, but I lost the ability to reopen links from other programs.
Hello
I did upgrade the portable version to .1500 and notice this :
When you check the version it says that an update was applied and you need to click on restart.
If you do so, the browser seems to close down but maxthon processes stays for ever in the task manager. Of course you can't start Maxthon again unless you kill the processes
15 minutes ago, Orlith said:
Hello
Hi Orlith, kindly restart your PC and try again.
10 minutes ago, BugSir009 said:
Hi Orlith, could you disable all extensions and also make sure you give full control for Maxthon under permission for account.
I can confirm. Auto update function crashes everyting.
It's not posiible to run maxthon aftter upgrade to 1500.
Restart doesn't help at all.
Delete all files, download 1400, and UNCHECK updating beta verions.
Maxthon 7.3.1.1600 Beta
Changelog:
https://github.com/maxthon/Maxthon/releases/tag/7.3.1.1600
Edited by alexzhus
  • BugSir009 changed the title to Maxthon PC 7.3.1.1600 beta
  • BugSir009 unpinned this topic
Join the conversation
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
